Results 1 to 10 of 22
Thread: Using E10 Ethanol Unleaded in my P38
    Sep 2009
    NSW
    Hi,
    New to Australia, I've been a bit wary about putting in this new E10 Ethanol fuel in my 1999 4.6 HSE. Is there any advice about it?
    All I can find on the forum is this about Series 1s...
    http://www.aulro.com/afvb/series-i-l...-e10-fuel.html
    However for the past couple of weeks I've been trying it to save on cash, particularly since the Sydney fuel cycle has moved to a Thursday (what fresh madness is this...?!) Cheapest fuel now on Thursdays
    And lo and behold... my poor Rangie is running a bit "rough", particularly on start up in the mornings, with more engine noise & a noticable knock on the engine... and I'm only getting 26l/100km on the urban cycle...
    Now... is this because I've changed the fuel, or shall I hunt for another reason?
    And yes, I'm changing back to the proper stuff for a couple of weeks, just to see if it makes a difference...
    Douglas Park, NSW
    Personally, I stick to the proper stuff.
    The fuel cycle still has Wednesday as the cheap day out my way. Took 280 litres last night at 106.9 cpl . That should see me out for a couple of weeks .
    Couple of points: ethanol molecules do not pack near as much combustion energy as their "equivalent" in hydrocarbons. so engines running on ethanol mixes need to burn more fuel to obtain the same energy output.... further, it does not burn as smoothly as does a more homogenous mix of hydrocarbons.
    Ethanol is not recommended for Rangies of the 90's because it can lead to the formation of deposits on the fuel gauge sender which change the resistance readings and ultimately you may find the gauge readfing only 50% when the tank is indeed full... there's a LR TSB on this... usual fix is to fit a new sender ($$$). Others (self included) who have suffered from dodgy fuel have reported success by dosing the tank with EFI cleaner and doing a long run...(500km +)
    I have been driving Bris<->Toowoomba fairly regularly over the past year or so and did some "experiments".
    The 4.6 engine has a relatively low 8.37:1 compression. When I fill up with 98 Octane /same servo/same pump the return 270 km journey averaged out at 12.2 litres/100km...according to pumped volume and GPS distance for 5 trips
    Ran the tank down twice -required 85L fill - using the 91 octane unleaded from same bowser (of course it was a different hose )
    I then undertook several more trips on 91 octane: result was 13.5 l/100km
    for all cases, the GVM was about the same and travel time was "off-peak" and elapsed time each way was 1 hr 35 mins +/- 5 mins.
    what I did notice was that on cruise control at 100kmh approach speed on certain grades, the AT held 4th gear on 98 octane... whereas on 91 octane it kicked down and roared away at 3000+ rpm to maintain the 100kmh!
    With a price differential of up to 14 cents/L it's still a shade under $3 more expensive to use the 98 octane irrespective of the improved fuel economy... but the engine does run more smoothly esp. under load.
    Sep 2009
    NSW
    Quote Originally Posted by lorkers View Post
    Curses.
    The other half has taken the Rangie to get her hair done, and has just called me to say that there was a loud bang, and it now sounds like farm machinery. On the phone it sounds like, well, not sure but a diesel on steroids is the best answer. Doesn't really sound like an exhaust problem, more like on the head, but I'm trying to diagnose it over the phone...
    So, may not get a chance to try it on proper fuel... Are there any good garages that know P38s in the Castle Hill direction?
    Dec 2008
    Victoria
    That sounds expensive - ouch!! Good luck.
    Davis Performance Landys
    Amaroo Park Complex
    233 Annangrove Rd
    Annangrove, NSW 2156
    (02) 9679-1978
    or
    Peter Davis (different bloke),
    Roving Mechanical Services (mobile mechanic)
    0410 503 500
    May 2008
    Quote Originally Posted by Hoges View Post
    Hmm, filled up my '99 4.0 with 98 octane before doing an approx 600Km round trip to Sydney today. Averaged about 15L/100Km with 4 adults and average speed of 110-115Kph (or thereabouts), corrected for 33" tyres and 4.1 diff ratios. Still seems a bit high to me.
    Maybe some injector cleaner would help?... or perhaps the top of the motor isn't quite run-in yet?... I'm pretty sure that playing with Sport mode and manual shifting in the hills and bends out the back of Douglas Park would not have had much to do with it
    The shame of it all - I even let a Hyundai Excel overtake me on the motorway coming home
    Lorkers - hope your Rangie is ok... there is also a bloke named Sam who is a mate of Andrew E on this forum. He is over Hurstville way, but I think he has a mobile mechanic business and knows his way around P38A's.
    Cheers, Paul.
    Quote Originally Posted by PaulP38a View Post
    Sam
    Rangeland Automotive
    Mobile Motor Mechanic
    Bexley Sth
    Mob: 0410 664 194
    Sep 2009
    NSW
    Quote Originally Posted by Grumbles View Post
    Thanks for your support guys... and the contacts for garages that I'll need shortly... not today thankfully, as I've at least got it back on the road, although it's not exactly puring... more sort of clunking.
    Fault was obvious when I got there... the big hose with cooling water going into the top of the engine had come off (or, from the look of the dent in the bonnet, exploded off) and the jubilee clip & dangly hose was clattering against the fan. Now if the other half had mentioned the poor Rangie was spewing coolant all over the car park (or, should I say, leaking & marking its teritory), I'd have told her to switch it off RIGHT NOW.
    Once things had cooled down I got the hose back on, and filled back up with water... lots of water, the rad was drained. Goodness knows what damage driving it along with no coolant has caused, but its sounding sickly, and the alternator (which had gallons of water sloshing over it) is making a nasty squeel too.
    Original fault seems to come from the coolant system, which even now has hoses that are rock hard, so I guess pressure related, and a blockage?
    Sigh... going to take it to bits over Christmas... That'll be fun...
    Aug 2010
    Pakenham
    Just wondering whether hte p38s have variable ECU's in them. Cause the recommendation is to run on 91RON fuel as we have the low compression engine in oz. Some i'm suprised to hear that you got more performance let alone better economy out of it. Have you had your Rangie chiped or performance enhanced??
