Results 1 to 10 of 14
Thread: Later model door swap
    I have an 86 County with Series 3 style external door handles . What is the latest year with external push button handles that I could swap to?
    May 2006
    Why would you want to swap them? - other than I gather that the locks are apparently more troublesome than other types. When disadvantages of late types are considered, maybe best keeping what you have.
    With the later type, the inner liner comes further into the cabin allowing less elbow room. (note mine have been permanently removed.)
    The plastic outside door handles are more prone to damage by sticks, etc than the recessed ones. Also, the striker plates protrude more, and are good for ripping pants, especially the belt loops.
    Another "feature" these striker plates have is plastic around the round bit that the lock grabs. This rapidly wears out. It is basically plastic hose with 10 mm OD over 8mm rod. Have rebuilt mine using rod from 10 mm bolt.
    Not strictly true Cooper. Post 2004/5 (i think) ones from memory are a one piece steel galvanised door in the same vein as the post 2002 rears. They are much better.
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    The doors changed in 1987 to the push button handle. The earlier doors are thinner, hence more room, but the early doors probably tend to rattle more. Not sure which rusts better - both types rust quite well. 2007 on I believe have steel skins. Very early 110s had doors the same as Series 3, and all doors are interchangeable, with changes to the striker plate and door check to suit, from the first Series 2 in 1958 until current Defender.
    Okay
    All good feed back as usual
    Will stick with the OE doors then
    ahh but when did they goto roll down windows?
    Toowoomba, Queensland
    1984 (he says confidently, with nothing but memory to back him). I think the initial 110s had sliding (but angled) glass then winding windows came out with the 90.
    Certainly all 110s I've seen in Oz had winding windows. We had some of the last Stage 1's and Series 3's though (there was production overlap for a year or so).
    Against that confident timeline, are the photos here:
    Land Rover History: Defender 90 & 110
    showing even a 127 with sliding windows. I wonder if the poverty pack versions had them for a while?
    Steve
    2003 Discovery 2a
    In better care:
    1992 Defender
    1963 Series IIa Ambulance
    1977 Series III Ex-Army
    1988 County V8
    1981 V8 Series 3 "Stage 1"
    REMLR No. 215
    There was a Blue 110 County at the LROCV trip to Dargo last Aiust day weekend with the angled sliding windows.
    I also have a 1983 Stage 1 109" that has straight sliding windows as fitted to series 3's
    JDNSW's Avatar
    All Series 3 had sliding windows. Same but with angled join on the glass for the first 110 in 1983, although at least some of the press vehicles were the same as Series 3. The windup window was introduced in 1984, around the same time that the 90 was introduced, and may have been optional at first, although I have never seen a 110 or 127 (or 120) with factory fitted sliding windows, except military ones. Sliding windows with removeable door tops remain standard for military models, and probably could be supplied for civilian ones.
    As I said, the doors are all interchangeable, so you can't go on what is fitted today.
    Nov 2008
    Usually somewhere
    22.04 MB
    Old 110
    I have an old 110 factory tray-back. It was first registered on 11th Dec 1984 (25th birthday yesterday - filled the shot glass a couple of times with a fine single malt on his behalf ), the original motor was a 2.25 litre petrol, and it has the angled split sliding windows on separable window frames. Doors are lined.
    However, as JDNSW said above, all are interchangable... so no way of knowing if mine are original kit or not.
    Phil
