Results 1 to 2 of 2
Thread: Front Springs Replacement
    Feb 2009
    Newborough, VIC
    67.72 MB
    Question Front Springs Replacement
    I am changing my front springs (thanks Tombie) on my 2002 D2V8 this weekend. Does anyone know of an instruction sheet for this task?
    biggin
    99.87 MB
    Support front end on chassis stands.
    Do one side at a time.
    Remove wheels
    undo the 2 lower shock bolts
    Apply spring clamps
    Drop axle
    Push shock up and tie in the closed position
    compress springs
    remove spring
    replace spring
    raise axle as high as possible
    locate lower shock mounts, locate the spring perch and start the bolts
    loosen off spring clamps and remove
    Drop axle down
    tighten up lower shock bolts.
    raise axle and put wheel back on.
    NB:
    Don't pull on the brake lines - you may be better off removing the caliper if you want more work room or suspension drop
    Be mindful that the propshaft will hit on the Xmember
    On do one side at a time, not both at the same time - or make sure the axle is supported
    There will be roll resistance, you can jack the down to couteract this, but check nothing is hitting - like the propshaft on the Xmember.
    Slunnie
