Results 1 to 4 of 4
Thread: 3.5 disco v8 cooling system (hoses specifically)
    Jul 2008
    Ballarat, Victoria
    hey guys, im trying to get my discos cooling system the same as when i took it apart to replace the engine, the 2 heater hoses running on the drivers side of the engine go to the intake manifold and 1 barb on the water pump, i have gotten that far, now where does the other barb on the water pump hook up to? it sounds silly i know, but i forgot to take photos before i took it all apart and maybe im forgetting another hose or something
    any help would be greatly appreciated, pics would be even better! thanks
    Avoca Beach
    NOWHERE
    On my RRC 3.9 the stub towards the passenger side IE in the middle of the water pump is a blank and is not bored for a hose.
    I had a look especially for you.
    Regards Philip A
    Jul 2008
    Ballarat, Victoria
    thanks for that, my replacement engine is out of an 83 rangie so ill go and double check that it is blocked also
    Avoca Beach
    It probably will not be blocked so you will have to buy a cap.
    Regards Philip A
