Results 1 to 10 of 20
Thread: Suspension lift
    Mandurah. W.A.
    Suspension lift
    Anybody used Suspension Stuff in Brisbane. I am looking at a 50mm lift on the 04 D2, they're offering one kit for $730.00 and another with Bilstein shockies for $950.00. Info welcomed.
    Maggsie
    04 V8 Disco
    85 V8 County
    May 2003
    On The Road
    Go with the Billys,,,
    I used the $730 kit on my Td5 and I'm quite happy with it.
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    We have used them twice, very happy with them, they will set you up with the right kit for your car and needs
    Mandurah. W.A.
    Thanks for the info.
    Maggsie
    Aug 2009
    Brisbane, Sunshine Coast, Gladstone, QLD
    Just check the codes on the Bilstein shocks, when i spoke to them they where the standard shocks not the extended versions.
    However they could source the extended versions if requested.
    Jul 2007
    Hobart Tassie
    Quote Originally Posted by Landie_Addict View Post
    x2
    im using dobinsons coils 187lb front/240lb rear & lovell shocks from S.Stuff a good kit for the $$$
    cheers smally
    Ramingining, Arnhem Land
    fitting suspension kits
    Much the same as Maggsie, looking at a replacement suspension kit, possibly the 2inch lift. Main question to add, what's involved with fitting it yourself? Spring compressors would be one thing, how long would they have to be to fit the longer springs? Cheers
    uneven springs
    Another thing... I measured the centre wheel to arch on my four wheels, and found the rear right and front left measurements about 30mm lower then the rear left and front right measurements. Does that mean the springs definitely need replacing? or could new shocks even that up? And yes, it does wobble a little over bigger bumps!
    Apr 2007
    I am lost
    shocks dont even your ride up shocks are the cushions,,, springs are what give you height and leveling
    cheers kelvin
