Hi Guys,
I am not mechanically minded so all advice appreciated and forgive the non tech description.
I sent my P38 into my local rangie mechanic with 280,000km on her to confirm a ticking noise form under the hood. The car was idling well and running good however lacked power. Turned out to be the head gasket upon their initial inspection. They took the RHS head off and found the head and block is no good (melted?). Told me I have to replace the motor. They mentioned something about the water case leaking or something and that 3 cylinders had compression leaks. That would explain the lack in power I guess. They also said something about the sleeves - again I didn't understand
They've offered to throw in another motor with 160,000km on it for AUD$5,000 fitted with 3 month warranty.
If I go down this path what should I ask about the other motor? Should I get it compression tested, heads removed and inspected prior to installing in mine?
What are my other options that are good (well this is not good) on the wallet?
Is it worth getting the heads and block reco'd? Again, I am not a mechanic so know jack in this area.
I'd love a Stage 3 from V8 Reno's in the UK but for a car that is going to pull ~$10k (injected gas recently fitted) I am very hesitant to spend more.
My plan prior to this was to get a Defender for touring as the P38 Gremlins make me nervous. (I'm not sold on the Defender yet so perhaps I'll start another thead at a later date - it's just a box - where's the leather?)
Advice, thoughts and contacts appreciated!!
Many thanks,
Zem
PS: I am based NE of Melbourne, Australia.
Sorry, I also wanted to ask is it even worth looking at keeping her long term given she has done 280,000km?
If I replace the motor is that the first of many other bits that will need replacing? Is she too old?
I have had the rear diff, all air bags and radiator done about 12 months ago.
Interior is clean and I only do about 10-15,000km per year.
Thanks again
