Thread: Rough idling
    Dec 2009
    Perth, WA
    Rough idling
    So im not reposting old questions im trying to narrow my problem search a little, ok so my 96 disco manual v8 is running rough only when it is warm and at idle ( lights stop e.t.c) and i noticed today if i run my aircon it runs smooth at idle and as soon as i turn my aircon off it is rough again, once again only when warm, any ideas, so i am servicing it tomorrow and will be checking the MAF and speed sensor to solce these problems but i havent been able to find the IAC which i assume is connected to the speed sensor or simply is another name for the speed sensor, also the TPS will be checked, once again all opinions appreciated
    Avoca Beach
    The IAC is at the rear of teh plenum on the drivers side. You will see a big plug with 4? wires to it on the end of it.
    The idle issues of 14CUX V8s are caused by a variety of factors-
    High mileage so injectors drool
    spark plugs old
    spark plugs leads old
    rotor old
    dizzy cap old
    valves worn and leaking
    dirty throttle plate and body
    I always found that in my RRC , the idle always deteriorated after say 30 seconds, and mine was perfect. The idle is better with aircon on as the mixture is more dense in the chambers so fires more easily. Also the stepper increases the idle speed to compensate for the load.
    Mine now is much better with 4 hole injectors, but that is a bit extreme to fix a poor idle.
    IMHO you should start by replacing the plugs, leads, dizzy cap and rotor. Rotor must be Lucas branded even if it does cost 5 times the cheap Bosch ones. And clean the throttle butterfly as the dirt reduces the air past the closed butterfly.
    Regards Philip A
    Dec 2009
    Perth, WA
    spark plugs old
    rotor old
    dizzy cap old
    Regards Philip A
    ok doing the leads and plugs tommorrow, will look up reccomentdations for leads and plugs, also engine has only done 50k km's so dont think it's high mileage, wish i read this this morning as i didnt check the IAC or TPS today ran out of time doing the sump gasket(rtv sealant) and gear box fluid, but tomorrow is another day to try eliminate rough idle, i will say i put in mutol 10-40w fully sunthetic(not sure whast was in there but was black and had quite a bit of gunk in sump) oil 70$ 5 litres and it honestly seems to have made a difference with overall running, and yeah spoke to my dad about injectors and he said is big move and uneccessary unless your are doing mods and tuning e.t.c, but will continue to post until resolved so newbies can work it out with som ehelp, which i had but alot of time people dont post once victorious which is the biggest benefit because alot of the time the problem can be identical or ruled out and move on to next one! stay tuned
    mike 90 RR Guest
    I would start with checking of the TPS first ......
    Mike
    Dec 2009
    Perth, WA
    thanks mike got your pm and will definatley be giving it a go!
