Results 1 to 10 of 14
Thread: Signature
    Signature
    How do you guys put your signature and copyright symbol in the bottom of your pics....
    is there a specific program or can it be done in Lightroom/PS3 etc etc
    I created an action in PS that I run if I want to put a signature in the corner.
    mmmmm an action seems i have a lot to learn
    I do it as an opaque layer in photoshop. I have a keyboard macro that loads the layer over the photo, then compresses all layers and saves the file.
    I dont have as much to do with imaging as i used to and it only gets pulled occasionally when Im doing something that when used I want the credit to goto a certain place. OR if Im using to past identifications on something.
    Lou, you can record an action as you do the steps required. I'll put together the basics a bit later if I'm not to tired.
    Basically all I've done is record the creation of a text layer where I need it with a drop shadow. I actually have to update it as I put the year in the text.
    For Lightroom the Mogrify plugin works great and being free is always good. LR2/Mogrify - Add Watermarks, Border and Text Annotions to Images Exported by Adobe Lightroom 2
    Quote Originally Posted by inside View Post
    Inside it says I have to load in the imagemagick before I can use the other plug in but can't work out which one I need out of the several it offers for 32 vista...
    it offers 8 bit this and 16bit that
    I suspect 8 bit and 16 bit refers to image bits/channel. LR2 is only 32-bit like your Vista is.
    I'm sure it does but still doesn't help me know which one I should be loading
    ok so it has the file in the zip file I have downloaded but I will be bugger if I can get this pluggin to work there is no .exe file to run and opening lightroom to add a plug in doesn't work either
