Nifty,
i will double check at work tomorrow as i am sure i PD'd a new 3.0 HSE today & its spec was what u require wrt Sunroof & Rear A/C.
They were all there & functioning.
I have also just finished a press check on a vehicle that was also a 3.0 HSE with the lot & again it had all the bits.
Now i am assuming you have been told that the 3 dials/switch pack in the "roof" above the 2nd row passengers gets filled with a blank? Am i correct with what you are stating? I just want to get it all correct when i get into work tomorrow.
WRT the other functions that you cant get because you order a Sunroof is correct.
RSE/TV is because of glare apparantly
Yet it is fitted to the V8 HSE as standard!?
Adaptive lights....
I dont have an answer either
