Results 1 to 10 of 12
Thread: spare connector
    Oct 2006
    kinross, Perth, WA
    spare connector
    Well im geting more and more worried about my new defender, it doesnt seem to leak anything... and while checking the harness for oil discovered that it wasnt leaking either... bah call it a landrover!
    anyways... while looking i noticed there was a spare blue connector in there.. a multiway with some fairly hefty looking wires in it... but just floating around...
    any idea what its for? im just being nosey thats all!
    Steve
    Padstow NSW
    in where? that narrows it down to all of the car
    cheers phil
    Oct 2006
    kinross, Perth, WA
    i guess your avatar picture is right... hehe... sorry about that...
    i did mention that i was looking at the injector harness... just didnt mention which end! duh...
    im talking the ECU harness under the drivers seat at the ecu end. The harness has a spare blue connector next to the main ecu plugs....
    make more sense?
    Steve
    IIRC its the ABS loom Diagnostic
    Oh no! You've got the dreaded plug leak common to the new LR.
    The other end has fallen out somewhere whilst you've been driving.
    Scouse tells me it a very expensive repair.
    Oct 2006
    kinross, Perth, WA
    i'll take your word for it...
    i think its part of the ecu loom tho not the second loom that goes to the abs computer? it also has some very hefty wire as i said.. reminded me of the old headlight wires in the mini!
    thanks
    steve
    Padstow NSW
    can we get a picture?
    and the colours of the wires so we can look at the rave cd.
    cheers phil
    Oct 2006
    kinross, Perth, WA
    i'll look on rave later... been looking at microcat but can see anything on there... will let you know
    the plug is blue tho.. and the thick wires i think are brown and brown with white stripe...
    just thought someone might just say... oh yeah its this...
    Im sure Tombie is right... he usually is
    Ron
    Is it really that bad? do you think its terminal? to be honest im more worried that i'll have to rust proof the underside if it carries on this way... after the disco had its fuel pressure reg sorted that doesnt leak either now...
    at my house the reputation of landrover is on the line!
    Williams West Aust
    Ron
    Nothing leaks from an empty container
    Best check the oils and water Steve
    ENJOY
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    What model Defender is it?
