On the D4 fuse 31 in the passenger compartment fuse box is for the rain sensor (& reversing camera). If the D3 is the same then removing the fuse would probably stop the rain sensor but may not cause it to revert to normal intermittent operation. Maybe I'll need to try that before long too.
Edit: MY08 wiring diagram shows fuse 18.
. I have rain sensing wipers but on the intermittent setting on the least sensitive setting they are still far too sensitive. Any ideas on recalibrating the sensitivity or even the ability to change them back to normal variable intermittent?
