Results 1 to 10 of 27
Thread: 3 Amigo's after 220k..
    Ean Austral Guest
    Gday All,
    Well they finally appeared after 220,000kms, whilst the daughter drove here drunk dad home last night, then this morning after reading all about the 3 little buggers, start the car and they're gone..
    The car has been driven about 100ks today and still haven't re-appeared.
    Went to plug in the nanocom, but it wont link to the new laptop with windows 7..
    Is this a common thing for them to come and go or am I just lucky..
    Thanks and Cheers Ean
    midal Guest
    Ean
    Can only speak from my own experience but yes, they came sporadically with my D2 (180k's). First it was one or two very quick visits then slightly more often and hung around longer but always disappeared when the car was turned off and back on again. A couple of times they hung around for a while and would not go away for extended periods.
    In all such events however, the brakes worked as normal, I even tried a couple of emergency stops when safe to do so just to test them, no problems, even felt the pulsing.
    They would come at any time, soft braking to turn corners, cruising the highway at the speed limit, even when in car parks.
    Eventually went away all together and I haven't had a visit for a few months.
    Sort of like some of the annoying people you meet in life at times
    Mick
    Williams West Aust
    Hi Ean
    You can read/clear the faults without your laptop.
    With the ignition on the run position with engine off.
    Disable instrument mode
    use the side arrow key to find Disco Slabs
    press the ent key
    Nanocom should ask do you want to read fault codes ent for yes
    it will list them 1 at a time,at the end it will ask if you want them saved.
    one more press of the side arrow should ask if want to clear.
    I checked one yesterday for Taz,shuttle valve fault intermittent 254 times,he had 3 amigoes once.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Hi Ean,
    I had this problem with my vehicle at or around 250/260k Km's.
    I found it was a dirty connection at the connectors from the wheel sensor in the engine bay. They are a pain to disconnect as they have from memory a double o ring to keep clean. I found one of the terminals starting to go green....I cleaned this terminal & did all 4 sensors & never had the problem again. It may be a sensor that has died or a broken wire, the new sensors are now a one piece unit that goes directly from the hub to the SLABS ecu behind the glovebox. It gets rid of this connection that can sometimes be a problem.
    Ean Austral Guest
    Hi Ean
    press the ent key
    Goodluck
    Andrew
    Gday Andrew,
    After alot of stuffing around I just did what you said, and I had the exact same reading..Intermit shuttle v/v fault 254 times..
    Now I need to just spend some more time playing with it and learn more about it
    Williams West Aust
    Hi Ean
    I wonder if the Slabs computer can only count to 254.
    Tazs D2a had 254 counts on the shuttle valve,Ive had 254 counts on a rh front speed sensor in the past and cleared a 254 cout on a lh rear speed sensor yesterday on mine.
    A tip to keep the shuttle valves in order,regularly find a steep hill,even bitumen and use the HDC.I do mine every couple of weeks.
    Goodluck
    Andrew
    Ean Austral Guest
    Hi Ean
    Goodluck
    Andrew
    Hey Andrew,
    Was thinking the same thing maybe it runs out of things to count at 254 so it looses count and needs to start all over again
    Mine also had something about the rear height level but its a coil sprung car so not sure about that.
    Will need to read the manual alot more as the car is due to get the brake fluid changed so I have read you can do a power bleed using nanocom.
    That should be interesting, they sure are alot different to boats, I changed the fuel press reg the other day, and was due to clean the inlet manifold, so did them both at the same time, glad I didnt try and do the FPR with the manifold on, think I might still be there.
    Im used to manifolds and engine blocks you can get your hands in, not these ones where you need a 10y/o size hand..Oh well its all fun and good to learn.
    Getting on the big Silver Budgie tonight, so have a happy and safe new year and catch up when we get back..
    Nov 2007
    home at last - Port Macquarie NSW
    no-one heard of binary counting, 0 to 254. its computer speak. sounds to me the amigos show when the binary counter runs out at 254. i figure this is why i get the amigos show up more often in long trips than short trips. each time the alarm is set it resets the slabs ecu . but on a long drive theres more chance of hitting 254 faults in 1 drive.
    Zute Guest
    Yep, when ever Ive had the fault appear, its 254 times. But I'm sure it done it without the car moving.
    Ean, run the power bleed with the Nanocom, with your foot pressing hard on the brake pedal. Do this two or three times. Than run the test on each wheel, again pressing hard on the brake pedal.
    It will make a God orfull noise and push back against your foot.
    This activates all the ABS valves and will move the fluid and hopefully bleed any air out of the modulator.
    Hi there! I have these 3 amigos in my Defender 2001 from a month ago, It doesn't go and ABS is not functional. Nanocom keeps informing that pump is not responding. However, pump used to make a very loud noise until I tried to purge the system with power bleed a lot of times without pressing the pedal. Do you think this could have damaged the pump? how can I confirm ABS pump is not more useful?
