Results 1 to 10 of 27
Thread: Datsun Bluebird Suspension
    jplambs Guest
    A decidedly non Landrover question. I have a datsun bluebird 1981 model and it has sagging rear suspension. Anybody know of a good place in Perth to get new springs and shocks for it? Thanks everyone.
    Jonathan
    Mar 2007
    South Arm, Tasmania
    Spring Works in Perth should be able to make the springs up for you. They have a number of branches around Perth.
    Cheers .........
    BMKAL
    Williams West Aust
    You should be able to order them from any DECENT parts supplier.
    A mate is building a Datsun Sunny junior speedway car for his boy,he ordered his suspension(coils shockies and front struts) in from Auto One or similar in Gosnells.
    Not likely to be a stock item but are still available.
    Any of the children working at Supercrapp or Malz possibly wouldnt know what a Bluebird was,probably send you to the pet shop
    The guys at the MAIN Repco branch(where the wharehouse is) in Welshpool can be handy depending on who is on duty.
    They were a good car them bluebirds.
    GOODLUCK
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Rangier Rover Guest
    That's got some age on it They were a bloody good care in their day don't worry. I had one Go very well with a weber carby
    I never had major spring issues with mine (Was cured with home made spacers) but may I suggest if the new springs are difficult to find take some measurements and who knows what may interchange from the wreckers The car would be worth about 250 to 500 bucks so don't over capitalise on it
    May 2008
    Bundaberg Qld
    IIRC, a Bluebird (in the very capable hands of George Fury) holds the lap record around Mt Panorama (Bathurst) in the old track configuration. ie. before they put the chase in at the end of Conrod Straight.
    history lesson over, please carry on
    Paul
    Back down the hill.
    Quote Originally Posted by pop058 View Post
    Paul
    Mar 2009
    Derbyshire UK
    Paul
    yes just beating a Bloor Knox engined (split screen) Morris Minor driven by Group Capt Sir Gervaise Bartle-Mellors DFC and bar(Rtd)
    who rolled just going in to the drivers toilet block..
    jplambs Guest
    Thanks for the replies guys, I'll chase them up and see what I can find. I'm driving home to S.A. in March with it and the poor thing has to pull a trailer so thats why I figured I should probably do something about the springs/shocks. She has done almost 400,000 kms now, I had to paint her a little while ago because some of the cops up in Perth couldn't understand how a country car could have barbwire rust scrapes over the back. Its been a pretty reliable car though, the only maor thing I have had to replace has been the torque converter plate.
    And while we are on it would anybody happen to know why the engine screams at me when cruising at 110? If I accelerate a little it pushes past it and the same if I ease off the accelerator. Thanks again everyone.
    Jonathan.
    jplambs Guest
    Well just to keep the questions going on my Datsun, coming home from Perth tonight about 40kms out from home my bluebird started sounding like a Harley crossed with a tractor. It was a gradual change, the engine has been making a soft tappet sounding noise for awhile only now its a dull roar, there appears to be air escaping somewhere around the inlet/outlet manifolds but I can't see any holes, although the air coming out was fairly hot so I didn't want to get burnt and just drove home quitely. Anybody got any ideas?
    May 2003
    On The Road
    hmmm,
    L20 bored to 2180,
    flatop TRD pistons,
    280zx valves,
    72 cam,
    D shaped inlet ports,
    35"long secondaries,
    twin 48's,
    (mine also had a flowed crank believe it or not!)
    option1 5 speed,
    rear diff out of the FRONT of a 720 nissan,
    front struts out of a '68 model 1600(2" lower)
    The SX model had larger front rotors,
    oops,,
    drifted off there--
