Remove the ash trays and you will find 4(may be 3) screws behind each, remove these screws and then pull the cup holder mechanism out.
Now you can access the clips on the side of the climate control ecu. Push the clips in on each side while pulling the ecu and it pops out.
Take the opportunity to clean the ash tray and cup holder mechanisms and they will work with a much smoother action.
