Well I did a search before posting this but I could not find anything but I didn't look hard enouph.Well I had a look in the Good Oil section and found a post that Ron(p38arover) had of the A/C wiring diagram thanks Ron.
Also after reading Ryans(Ranga) post about his A/C and cig socket not working I put two and two together.
When I put the dash back in I must Ive tested the A/C with lights on and thought everything was OK.Anyway I had connected the white Ignition Pickup wire to the power for the light on the cig socketand not the power for the socket green wire. Pics below to explain
You can see the Ignition pickup wire connect to the power (red) for the light
Ignition pickup connected to the Green wire power for socket
