Results 1 to 3 of 3
Thread: FL1 boot door handle replacement
    Jof Guest
    Has anyone replaced the door handle on the boot/rear door?
    Mine felt a bit loose, and unfortunately someone tried to open the
    boot while it was locked and ripped the handle clean off.
    I think it had been repaired before, I can try and glue it all back together
    but the stress on it is probably too high.
    Any good ideas on where to buy a replacement?
    Cheers.
    Second-hand - try Triumph Rover Spares in Adelaide.
    Triumph Rover Spares - The World's Largest Land Rover Dismantler
    Dandenong Ranges - Victoria
    It is easy enough to change over with just a few fiddly bits to cope with.
    The mechanism is certainly a bit of a week point, I now treat it as a switch, squeeze to 'release' and then pull gently to open.
    The first one I bought from a wrecker was almost as crook as the one I had to replace, leading to a discusison with the merchant.
