Results 1 to 4 of 4
Thread: Clutch Master problem
    Nov 2007
    Hatton Vale QLD
    Hello All,
    Has any one had an issue with the Clutch Master producing air bubbles in the resivour when the Clutch Pedal is depressed?
    I can bleed the system and approx 10-15 clutch functions later i have no clutch and the gearbox does not like me.
    Dutchie10
    2000 Defender Wagon
    TD5
    Padstow NSW
    normal LR life of and LR master cylinder....between 8-10thou k's thats just life. i had 3 done under warrenty
    replace it with an alko trailer brake unit...i never had an issue after that.
    cheers phil
    As Phil says its a pretty common issue. Mine failed at about 50k km and I replaced it. This one is still working fine.
    Nov 2007
    Hatton Vale QLD
    Thanks for that,
    I had it replaced approx 2 years ago, and looks like i have to do it again, Land rover want $130.00 for a new one, but i di find that PBR do one for $49.00 for the same item.
    So now I'll try the PBR and see how it goes.
    Dutchie10
