This has got to be one of my favourite types of fishing. A lot of people however think it is too finicky and like fly fishing think it is too hard to learn. Wrong - it just takes a bit of practise. Watch the old blokes fishing for them. That's how I learned
I have fished for niggers in all conditions from on the rocks on North Head to still water on Narrabeen lakes. One of my favourite spots is down off Greenwell Point on the ShoalhavenRiver on a good run out tide.
Like all types of fishing it is just leaning the basics. The most crucial thing to get right is the depth to fish. This means having the right distance from your float down to the hook. More correctly, down to the last split shot as a lot of the time when fishing in any current or drift the bait will be perpendicular to the main line. I try to have my weed down around 1-2 metres off the bottom but adjust up and down until you find the depth they are feeding at. Weed cut up fine and mixed with sand and thrown in at regular intervals for burley increases your cahnces of getting them on the chew.
I agree the float has to be neutral buoyancy as if the fish bites and starts to swim away and feels too much weight they will drop it like a smelly rag. When the bite the float goes down and then wait 3 seconds before striking sideways the opposite way to the float down.
I use an Alvey Luderick Special reel on a 12 foot slow taper rod which takes all of the bumps and runs of a big blackfish when hooked. The main line is 20 pound so that it can handle being scrapped against rocks barnacles and weed on the ocean rocks but the trace is 4-6 pound maximum. Size 8 or 10 Gamagatsu green hooks finish off the rig. The other good thing about ****** fishing is the bait is usually on the rocks where you fish and the price is right.
If you have a stormwater canal near you more than likely there is green weed growing in it and this is also excellent bait in rivers and lakes. Cabbage weed is the best though if you are fishing off the rocks. Be sure you have the right footwear as it can get slippery – Cleats are the go down on the rocks
I think of this as my hypnotherapy as watching that float – and you need to watch it all the time is immensely relaxing. That is until a big 2 kg blackfish gets hooked – Then lookout and hang-on.
Bled, filleted and skinned, they are one of the best eating fish in the water. I could write more but am going out to grab my ****** rod and head down the rocks in the morning
Chenz
I do not wish to be a member of any club that would have me as a member
Former Owner of The Red Terror - 1992 Defender 200Tdi
Edjitmobile - 2008 130 Defender
