Results 1 to 10 of 11
Thread: Ice craft caravaner 85 operating manual
    real Guest
    Smile Ice craft caravaner 85 operating manual
    Hi all
    I have a caravaner 85 fridge lying in my garage and would like to Know how it works. I see 12v, 220v and gas can be used so my question is can it run only on 12v battery power or does it need gas too.
    Thx real
    Back down the hill.
    Quote Originally Posted by real View Post
    Hi all
    Thx real
    It's a three-way unit, it will work on any of the above, independantly.
    miky Guest
    Nice to see you got a faster answer here than on the other site
    Just went and had a look for Thabazimbi on Google maps.
    Seems to be a large mine nearby. What do they get out of it?
    Mike
    real Guest
    Hi Mike
    Its a mountain consisting of iron ore the word thaba means mountain and zimbi iron in the local language (Tswana) or something like that. Thanks V8Ian will try it after work.
    Perth W.A.
    though your fridge is a three way better ensure it doesn't need a voltage dropper for 230 volts
    miky Guest
    South Africa is 230V 50Hz same as Australia.
    It may say 220V, but will work fine on 230V
    Mike
    real Guest
    Will the 12v and 220v use the same elect cord with the 3 pin plug on thats the only cable that I noticed
    Back down the hill.
    Very much doubt it.
    miky Guest
    If the cord plugs into a mains socket in your house then that's the 220V one.
    There should be another lead with two wires which will be for 12V.
    The fridge works on the absorbtion principle which means that it uses a heating element rather than a compressor.
    The heating element can be heated by a gas flame or from a 12V element or a 220V element.
    Suggest you plug it in and make sure it works before worring about the 12V and gas side of things.
    Mike
    Melrose SA
    Never found one that worked in temps higher than the high 20s I would ditch it personally
