10th January 2010, 04:49 PM
rewire aux socket to 2nd battery
I have recently installed a 2nd battery and controller. I have put in a new 6-way blade fuse block and have started to migrate accessories like UHF & GPS onto it.
I want to rewire the rear aux socket and front cigar socket to the 2nd battery (off the main).
I have the circuit diags off the RAVE CD, so know that aux socket is fuse 32 in the front fuse bank. Which is the plug socket and/or wire at the rear of the fuse bank that comes in from the rear. I know the colour of the wire (green/purple) - but cant be sure where it enters the fuse box.I want to cut this and rewire it to the new 6-way blade fuse box off the 2nd battery.
I dont really want to run a new wire to the rear, the original is 25A anyway so is more than adequate for a fridge.
Anyone done this before?
10th January 2010, 08:48 PM
I "think" this is what your asking.....
10th January 2010, 10:12 PM
Thanks, this is what I'm after ...
Will I be able to simply cut the No. 3 wire and redirect to the 2nd battery (via the 6-way fuse block) ie confirm that cutting this will not affect anything else?
Do you know where the front cigar lighter wire comes into this fuse block?
11th January 2010, 04:39 AM
#4
Cig lighter here,
as far as what you want to do, yes simply re wiring should do the job. Protect the AUX socket with a 25 amp fuse, and the Cig socket with a 20amp fuse
I "personally" would leave the cig socket, its a pain to use as it gets in the way with stuff running from it, I would just install another socket some where else, but the way you want to do it will work. If you use bullet connectors, you could simply reconnect them at a later date if you need to.
I put one here...
14th January 2010, 12:38 AM
#5
So here's a thing ...
I have rewired both the aux sockt and the cigar lighter to the new battery and there's a problem ...
The car will not lock, either with the remote or the key, when using either method, the door lock actuators dont operate and the horn sounds once.
Am I going to have to undo the rewire?
There's a post on the Lnadroveronly.com forum where someone had a similar issue but his related to something he'd connected to the cigar lighter - he solved his by removing the accessory connected to the socket - my 'accessory' in this case is the 2nd battery !!!
Anyone got any thoughts?
14th January 2010, 01:01 AM
#6
As an interim step, I have removed the fuse (in the new fuse block) for the cigar lighter and the problem has gone.
Seems that the 2nd battery is energising something in the door lock system.
Here's the post from LandroversOnly:
DII Won't lock - Sounds horn - Hawkeye results - Land Rovers Only - Land Rover Forum
If no-one comes up with any bright ideas, I'll revert to original for the cigar lighter.
14th January 2010, 04:55 PM
#7
Very strange that is, but atleast you know "what" is causing the issue, just got home from nightshift so brains a little "weak", but will def have a good look at diagrams when I wake up to see if I can work out why......
14th January 2010, 10:57 PM
#8
My first post on here so hi from the UK, great site and some cracking Disco's
Having looked at the wiring diagrams I think this is the situation:
First off the fuse that supplies the cigar lighter socket (F15) also supplies several other items, amongst them the BCU, and is monitored by the IDM (Inteligent Driver Module). The wire that comes from C0587 feeds a header that supplies all these items, except the IDM which is integral to the fuse box. Therefore it is highly likely that back feeding the cigar lighter with a voltage will confuse the BCU or IDM and prevent correct operation of the central locking and/or alarm system even when disconnected from the fuse box since the BCU is still connected to the cigar lighter.
If you want to feed the cigar lighter socket from an aux battery then you'll have to disconnect it further up the loom at header C0291 pin 12, which is buried under the dash in the passenger footwell. I'd suggest that UP's option of fitting a new socket will be the easiest and will also give the option of an ignition switched socket as well as a permanently live one.
Secondly, the rear accesory socket (a) doesn't get monitored so should be fine but (b) whilst it is rated at 20 A (IIRC) the wire that feeds it is quite long and has a significant voltage drop on it. If your load is more than around 5 A (and certainly if it's 10 A or more) and has an undervoltage shut off system you may find you cannot get as much run time as you expect. I would suggest running a much thicker gauge cable to the back to minimise voltage drop. I tried an absorption fridge on mine, that drew around 13 A and would shut off after only a few minutes when the engine was switched off. The socket in my D2 is supplied from the standard LR battery (no aux battery on mine) and the fridge shut down voltage is around 10.5 V. A compressor type fridge (Engel/ARB etc.) obviously draws considerably less, but still worth checking the drop.
Anthony.
