10th January 2010, 09:27 PM
93 Range second battery
93 Rangie V8
Has anyone fitted a second battery infront of the airfilter.
If so can you please assist on where to move my power steering reservoir.
I will also have to move my vacuum pump but this should be easy.
Any help and pics would be greatly appreciated.
Peter
12th January 2010, 08:30 AM
Mine is a 92 with V belts but I just moved my PS pump between the alternator and battery cradle by making up a bracket fitted to the corner of the cradle. The bracket is quite simple , being just a straight piece of metal with the reservoir clamped on with a large hose clamp. Hasn't moved in 100K of often worst corrugations in OZ.
BTW you know that you need an AGM or other sealed battery as you do not want any acid vapour in the MAF.
Regards Philip A
