Results 1 to 10 of 12
Thread: How to torque drive shaft bolts?
    Ferny Creek (Dandenong Ranges) Melbourne
    I dropped the front drive shaft out the disco this morning to have greaseable UJ's installed in the cardan coupling, but I could not get a Torque wrench / socket onto the nuts/bolts and so am stumped as to how I can torque them up when I reinstall the shaft tomorrow. Does anyone have a clue how I can get the correct torque on these bolts?
    Also, I planned to replace each of the 8 nyloc nuts with new ones, or is it preferable to use normal nuts, spring washers and maybe some Loctite.
    Any bright ideas welcome!
    Ian
    Adelaide - Torrens Park
    Use new nylocs. I just do them up tight to very tight.
    WA
    They are a PITA to get at. I just do them up as tight as I can with a spanner.
    99.87 MB
    Same, just spanner tight. Its not a very critical tension on them.
    Slunnie
    Thanks Slunnie, Isuzurover and Bigjon. New Nylocs, a hearty breakfast and a decent ring spanna should do the job! What would I do without this forum? - probably have a mental breakdown and buy a Toyota - perish the thought!!
    Ian
    99.87 MB
    Don't even need a heart breakfast. Just tight is fine. If you do them up FT you'll round them when you go to remove them next time or you'll strip the nyloc.
    Slunnie
    Thanks Slunnie, good point, I always swing on the spanners too hard, thats why I prefer a torque wrench whenever I tighten anything. Tomorrow I will keep your 'words of wisdom' in mind.
    Ian
    a 3/8th drive socket extention and adaptor for the torque wrench is all you need.
    The tool from Koken looks like a socket with an extension on it? If that works then fine, I can use a torque wrench, but failing that, a couple of spanners will do just fine.
