Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: HOW HOT
    Nov 2006
    cardiff ,NEWCASTLE.
    Angry HOW HOT
    Ok i made a shrowd & put the bigger fan on ,only using the electric temp gauge now..seems ok but after i fitted the shrowd i started the car & it was only running for about 5minutes & the radiator was hot i couldnt put my hand on it should it be that hot in such a quick time...??????????
    Adelaide - Torrens Park
    If it was just idling I wouldn't have thought it would be that hot that fast.
    Nov 2006
    cardiff ,NEWCASTLE.
    idling with choke on was cold ...
    somethings wrong there....
    check
    the lower radiator hose for temperature with a blanket in front of the radiator from start when the top hose begins to get warm if theres no increase in temp at the bottom theres no flow, either the radiator is blocked the thermostat is stuck closed, the pump is eroded or you have a hose bockage.
    the timing of the valves, the spark and for restrictions on the exhuast do a leak down test on a cylinder thats on the exhaust stroke.
    If the timing is out the engine will be fighting itself to keep running, it will get hot just trying to idle you will be down on power.
    Is the fan too big, is it creating too much flow and not allowing enough time for the coolant to transfer heat to the atmosphere?
    if its none of that then I have no good news for you.
    Williams West Aust
    Is there anybody with holden 6/Series experience that can look at this for Banjo.
    He has been chasing his tail for a long time.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Brisbane, Inner East.
    Does the bottom hose have the anti-collapse coil in it? The water pump sucks the hose flat if there isn't one and thus no water flow. Make one out of a wire coat hanger if necessary.
    Have you had the core rodded out?
    URSUSMAJOR
    Williams West Aust
    This is an ongoing issue in another thread Brian,radiator is new.Anti colapse spring is a good point that hasnt been mentioned.
    Would be good if somebody near Banjo with the experience could go thru it with him,it has to be a simple issue thats been overlooked.
    Andrew
    Loganlea Qld
    Does the radiator stay as hot as you describe or is this just the initial "thermostat opening" surge?
    It should be running around 80degrees or so and that is fairly hot to touch.
    Is this a Holden powered vehicle? If so the position of the fan to the radiator will naturally be out of kilter. I would suggest in this case either a larger radiator, a cross flow radiator or cheapest of all an electric fan.
    Still check for blockages as mentioned elsewhere though.
    Glen
    1962 P5 3 Ltr Coupe (Gwennie)
    1963 2a gunbuggy 112-722 (Onslow) ex 6 RAR
    1964 2a 88" SWB 113 251 (Daisy) ex JTC
    REMLR 226
    Coolum, sunshine coast,qld
    overheating 202
    gday,from what i remember from the ist thread you have now made your radiator more eficiant at cooling with the shrowd now,however when running it will get very hot to handle, (remember 82oc thermostat opening, this means it should keep it all running at that , theretically). It shouldnt get that hot that fast, mine takes about five minutes also but after that it is maintained-----. I think that the engine modifications you mentioned may be the cause of its increasing heat.i think you mentioned it had different carbies , a hot cam and a 60 thou overbore? This is asking for trouble to cool when a forby is offroading! check if its not running rich,the timing is probobly out due to the cam differences and 202,s are known to run hot on a overbore as the gaps between pots get smaller and clog up causing restricted flow. check your total water capacity of the system when filled , if its smaller than the standard 202 system you nead to increase.
    Nov 2006
    cardiff ,NEWCASTLE.
    Andrew
    na no lower spring but it doesnt suck the hose atall.its ok doesnt do a thing to it.
