Page 1 of 8 123 ... LastLast
Results 1 to 10 of 73
Thread: Maxi drive reduction gears
    Eidsvold QLD
    Finally got to use them in anger on the weekend and was very happy BUT they howl like a hyena (for those that have never heard a hyena howl, think frozen dog and chainsaw). Supposedly Cog cognisant folk I have spoke to have said that is due to the new gear meeting the slightly worn gear.What are the experiences of other installees?
    The Ugly Duckling-
    03 Defender Xtreme, now reduced by 30%.
    a master of invisibleness.
    Kingston, Tassie, OZ.
    Quote Originally Posted by crump View Post
    Crump IIRC they are straight cut gears, therefore not any different in design to reverse gears in most vehicles. Is it a similar noise?
    Helical cut gears are almost silent by comparison.
    JC
    I had the 30% reduction gears. They whine because the new low range gear set use spur gears (straight cut), unlike the original helical gears.
    There are 2 new gears for low range. Whoever said there was a new gear meshing with a slightly worn gear is talking out of where the sun doesn't shine.
    Eidsvold QLD
    yep sounds like reverse whine just louder, so its normal??
    The Ugly Duckling-
    WA
    My 49% gears are getting finished off as we speak!!!
    Yes i'm afraid they are quite noisy
    JC
    Eidsvold QLD
    Thought you were getting 30%? Make sure you specify loudly, I asked for 49% and got 30% anyway, too late when the box was back here.
    The Ugly Duckling-
    WA
    I asked for 49% - we will see what turns up. I have to grind part of the case down to only 3mm thick to fit the 49% gears!!!
    Tassie/Perth
    You get used to the noise - or turn the radio up.....
    NSW , Pennant Hills
    Is there any Grinding of the Transfer case housing with 30% reduction gears?
