Results 1 to 2 of 2
Thread: fuel filter & transmission
    dennis brine Guest
    Question fuel filter & transmission
    disco 3
    can anybody tell me if the fuel filter also removes water?
    also, have been told should fit larger transmission cooler if towing a lot (3 ton van in my case) - in the bush whenever I can get there - any comments?
    the fuel filter will sperate out a little wate but not much its not designed to catch bucket loads.
    yes if you tow lots with an auto in australia you should fit the biggest cooler you can afford/squeeze in.
