Results 1 to 9 of 9
Thread: HELP !!! The Constant Chime/Beeping is Driving me Crazy
    Vazza Guest
    So my problem started this morning...
    2004 D2 Auto TD5
    This morn on the way to work a fairly loud and annoying BEEPING started. There are no lights showing on the dash and the car feels as if its operating perfectly, other than this damn random beeping.
    Its a totally different beep to that of the Diff Lock, HDC, SLS so it has me stumped. It appears to come from right behind the dash cluster and is usually a series of 4 beeps about a second apart maybe a little quicker. Sometimes there are 5 chimes and sometimes only 1. It happens both while driving and stationary.
    Has this happend to anyone before? Any ideas would be great as its really driving me nuts?
    Another bit of info about my car is the soleniod bushes on the starter motor are starting to go I think as some times it doesnt start on first turn of the key and just 'clicks', turn her off then try again and all good. Having that looked at on Monday.
    PLEASE HELP
    Melbourne, Australia
    Quote Originally Posted by Vazza View Post
    2004 D2 Auto TD5
    PLEASE HELP
    I don't think I've ever heard a beep from my D2a other than from the reverse park sensors and this is a very different sound to the 3 amigos chime which is more of a "ding ding" sound.
    Do you have any aftermarket accessories such as a phone car kit that could be causing the "beep"?
    Franz
    2004 Td5 auto with mods
    Ean Austral Guest
    Do you have an aftermarket water level senser..or a dual battery moniter..
    Cheers Ean
    Malanda FNQ
    Talking beep beep
    Betchya its' a mobile phone beeper thingamigig probably tucked up under the centre console orunder the dash---I have the same thing from my previous mobile connection
    Bacchus Marsh Vic.
    Head lamps left on chime? Sounds like a clock chime.
    Check all the fuses would be my starting point, good luck.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Williams West Aust
    They were bitchin about tailgators on the wireless the other day.
    Does yours have park sensors??? One of the complaiants were freeway drivers driving so close the parking sensors were activating
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Vazza Guest
    Thanks for all the replies.....
    Bit of background, am the second owner of the truck and it does happen to have one of those wired in nokia car phone kits. All though when I push the button on the car kit (pretty sure its the button you would push to answer a call) it makes a different sort of beep than the one thats driving me crazy?
    I guess in the process of elimination, I should have the old car kit removed and see if this stops the beeping.....
    Jun 2008
    CNS, FNQ
    Hay
    for the non starting problem where it just clicks, we had that, I cleaned the earth wires on the starter moter (easy access) and it solved it.
    it's quite easy and simple and will probably save a fair few dollars at the stealership
    cant help on the beeping though....
    Hay Ewe
    If you go thru the operators manual it should give you a list of the warnings and the frequency at which they beep. Most will activate with a warning light but there are ones that don't.
    andrew
