 Master
						Master
						01 TD5 Defender 130
Is there a power wire somewhere that is only active when the engine is actually running?
I used the brown wire from the alternator, but there doesnt seem to be enough current to engage a solenoid. As soon as its connected, the battery light comes on too
I thought of using that wire to power a relay and then the solenoid, but its essentially the same as just a solenoid.
Fraz
the oil pressure warning light.
its on when the engine stops but its easy enough to wire up a relay to that and the ignition relay so that when the engine oil pressure light goes out the relay contacts change over.
