Results 1 to 3 of 3
Thread: Viscous Fan Bearing
    Ean Austral Guest
    Viscous Fan Bearing
    Gday All,
    Have started my list of jobs on the car for our up-coming canning trip and will be putting a new radiater and intercooler in this week once my thermostat and hoses arrive.
    Whilst I have it all off the front I intend on doing the fan bearing as it hasn't been done yet and the car is now nearly 9y/o and done 220000ks.
    all bar the need of the 36mm spanner is there any other goodies I will need, the bearing should be able to get thru CBC bearing co, but other than that anything else.
    I get my rave cd back tommorrow so will check that out..
    Thanks and Cheers Ean
    I assume this is a Td5 as the V8 doesn't have a fan bearing, only the viscous coupling on the water pump. (I know nothing about the Td5.)
    Bacchus Marsh Vic.
    A quick bit of reading for you Ean,
    http://www.aulro.com/afvb/discovery-...shaft-td5.html
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
