Its just a ZF,, pull the plug on the side to check,
service as per previous models.
There is a previous thread on this in here somewhere,,,,
I am considering purchase of 2006-2008 D3 TDV6, but was told that later model auto gearboxes are sealed & considered a no-service item.
If this is true how do you check & change oil? if used for serious offroad or towing as I do I don't think gearbox would last long is unserviceable.
Thanks,
Bruce
 Master
						Subscriber
						Master
						SubscriberHave a look at this link
http://www.aulro.com/afvb/d3-d4-zone...te-filter.html
Ryall
If it hasn't been used for regular towing , then leave it until it's
well in 6 figures . The wrong oil will stuff it bigtime so be careful who
services your 26hp trans..............
MAKE SURE that the motor is running when removing the side plug or you will wear a lot of oilThe oil needs to be pumping through the gearbox with the box in neutral and the motor running AND the temperature of the oil should be between 30C and 50C
to check the level. Good oil should be clear but if coffee coloured you need to do a double flush. I spoke to ZF and said my vehicle with all accessories and loaded for a trip is close to GVM and they said 'that is the same as towing'. The ZF website says that if Towing, high speeds or temperatures, then the oil should be changed at 80-120,000km. I did mine at 70,000km after the Cape York trip as it was dark coffee coloured
The oil is expensive
 ChatterBox
						ChatterBox
						Try getting the oil from a BMW dealer it is apparently cheaper.
 ChatterBox
						ChatterBox
						Have you got the contact details for ZF?
