Results 1 to 6 of 6
Thread: Auto Question
    South Yundreup,WA.
    Auto Question
    Does anyone know if the D2 V8 auto box is suitable for a TD5? Having aquired a D2 wreck one of the options I was fantasising about was an Auto conversion for the Fender. Is this possible or is it geared all wrong? Being a 2001 model is it ECU controlled? I am assuming an adapter plate is available. Already considering the trans box conversion to trial. Can the CDL from the Fender be used and is it a big drama?
    CraigE
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Williams West Aust
    Wouldnt it be easier getting the correct TD5 box/ECU??? Just turn it into a fishing buggy,YOU KNOW YOU WANT TO
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    99.87 MB
    The V8 shift points etc are all different.
    Slunnie
    Avoca Beach
    Maybe Ashtrans can answer but isn't a Disco 2 auto ECU controlled therefore dumb, so that the shift points would be determined by which ECU controls it?
    Regards Philip A
    99.87 MB
    Not sure. I had thought that the gearbox ECU controlled 3rd, 4th, the torque converter, shunt control etc...... but I'm not definate at all on that.
    Slunnie
    May 2003
    On The Road
    and yes Craig,, it will bolt straight on,,,
    not sure about in,,,
