Results 1 to 10 of 39
Thread: Holden V8 into a RRC
    Jan 2010
    Newman WA
    Im going to fit a Holden V8 into a RRC . Has anybody done this conversion ? Going to use a R380 box , There are 2 or 3 adapter plates out there to do it with , which one is the best ? What would the clutch arrangement be ? Ive got both Holden and chev pattern blocks and even Ford y-block crank in Holden blocks .Any help appreciated
    St Helena,Melbourne
    4.28 MB
    I would use the turbo block as you are more likely to find an adapter for it, since the 4.6 came out not many bother with a holden/ chev V8 unless its EFI. Dont know how long the R380 will last but T400/ T700 or beefed up ZF would be my choice.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2010
    Newman WA
    Thanks Loanrangie , yeah I have a couple of T700's ,thats the 4L60 , not the 4L60E, I just dont think there is an adaption from the T700 to a 230 tcase available , only seen adaptors to the T400 , which I dont like (unless you need a transbrake LOL).as far as Im concerned the Holden/Chev engines will have Twice the power for less than half the price and be more reliable and cheaper to operate than any Rover V8 .
    Stockton, NSW
    Theres definetly some t700 to LT230 adapters out there, i looked at a few for my conversion when i was considering using a an auto, i actualy ended up with a patrol 5 speed box with a bellhousing from dellow to suit the LS1 and a LT230 adapted to it....
    For the t700 to lt230, i think its overkill engineering or something like that in sydney that does them, if you look on outerlimits4x4 there will be more info on there about it i think.
    Jan 2010
    Newman WA
    Cal415 , rung around all the conversion mobs , and they all said bad luck , nobody does a Transfercase adapter to a T700 , 4L60 , only adapters for a T400 (yucky 3 speed ) and a 4L80E , which is nothing like the 4L60 (much longer , different splines)
    Hi 400,
    Another option is the Ritters conversion C4 or C9 auto in front of a truncated LT 95. I have a bulletproofed C9 version behind a Chev. Would buy a similar RRC tomorrow. Uses stock trans mount posi and driveshafts
    Shotlister had one for sale on here recently, don't know if it was a C4 or C9. Very nicely made bellhousing, adaptor housing, etc. And all very strong and simple.
    cheers, DL
    Quote Originally Posted by 400HPONGAS View Post
    why bother, all you will gain is a close relationship with your driveline supplier.
    Safe Travels
    harry
    Yinnar South, Vic
    Have mate building an adaptor to suit T700 4 bolt on ext. housing, not 4L60E which is 5 bolt, to LT230 after a huge ****fight with Overkill, that seen him reclaim his money, he is close to completion, but not planning on parting with any until its tried and tested
    Yinnar South, Vic
    Quote Originally Posted by harry View Post
    Because some of us don;t like being boring
    Depends how you drive I think. Mine still has 3.54 diffs and 10 spline axles and have had no probs. The spare 81 I bought about 4yrs ago that had a 3.5 had more worn axle splines than the ones that had been behind the chev since 91.
    Mine gets flogged on the road, and cruises through the scrub. C9 / LT 95 is pretty strong, way stronger than a ZF.
    Waiting for the 'unbalanced' RRC with iron block posts now.
    cheers, DL
