Results 1 to 10 of 15
Thread: Brass radiator plugs Where from?
    It'sNotWorthComplaining! Guest
    I went to 2 plumbing supplies today looking for those Brass plugs to replace the plastic radiator ones.
    None of the places I tried had the Flanged headed plugs.
    ( No, I know I can get them at some Land Rover places) But I wish to know what they are originally made for.
    Brisbane, Inner East.
    go to a supplier of hydraulic hose and fittings.
    URSUSMAJOR
    SW of Geelong
    CLR has them on Ebay.....................
    Land Rover Defender TDI Brass Radiator Plug Set
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Quote Originally Posted by It'sNotWorthComplaining! View Post
    if you cant put your location in your description, itsnotworthtellingyou.
    but i am not quite that rude,
    you can get them from most land rover repairers or maintainers.
    try one of the sponsors at the top of the page here, and i know 'ricks 4wd centre' here on the gold coast have them.
    Safe Travels
    harry
    d@rk51d3 Guest
    The plugs you'll find at the plumbing stores will almost always be a tapered thread. So the further you screw it in, the tighter it gets.
    The plugs for the radiator will be a parallel thread, so it screws in all the way, and relies on the head and washer for a seal.
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    Got mine from local Autobarn.
    Jan 2008
    Nowra NSW
    The plumbers tapered brass plugs work fine and are cheap and easy to get.
    They work well on a R380 gearbux oil filler plug too.
    you lot are ****ing joking,
    the disco plastic plugs seal with an o ring under the head, and are a special plug, they look just like the plastic plug
    [which, by the way, are ok, until you stuff them undoing them with the wrong tool]
    but are made of brass.
    to put a tapered plug from a plumbing supplies into a straight thread hole is stupid.
    save your money, and buy the right thing from a land rover supply mob.
    and if you don't
    don't call me when your radiator is rooted on the birdsville track
    Safe Travels
    harry
    Never mind, I've found a trade supply.
