Results 1 to 10 of 17
Thread: Touch lamps and ceiling fans
    In my role at home as provider, cook, IT support, mechanic, gardener, handy man, pool lookerafterer, bug killer, dog and son chastiser, I have to deal with many issues and overcome some all sorts of challenges.................but I'm stumped on this one.
    We just got 2 new bedside lamps, touch lamps. Look good, work well.............and turn themselves on whenever the speed of the ceiling fan is changed. This happens every night as SWMBO has a different thermostat to me so we are forever changing the speed.
    So first up....why does this happen?
    And second....how do you fix it?
    The fan is on the light circuit, the lights are plugged in to the power circuit. The study ceiling fan (approx 7m away for SWMBO's lamp) does not turn on the lamps.
    Feb 2009
    Padbury
    Is the cetiling fan a remote controll one?
    if not where is the fan controler in relation to the bedside lamps.
    Could be a spike when you turn the ceiling fan to a diferent setting. might be able to put in a capicator to limit the spike. altho would not know what size would work.
    Quote Originally Posted by Sparksdisco View Post
    Is the ceiling fan a remote control one?
    Its a 3 speed rotary switch on the wall, the same size as a light dimmer, on my side of the bed, next to one of the lamps. But they both turn on.
    Brissy! No flannos here!
    Hi,
    Had to remember way back on this one. The answer is actually quite complicated but luckily, I had to dumb it down for myself so if I can understand, maybe others can too!
    I have plagiarsed and paraphrased some of the text below coz my explanation was just too darn complicated!
    All touch lamps have touch-sense circuitry and antennae. These two components are the fundamental reason why touch lamps are able to detect your touch and then turn the lamp on or off accordingly. Similar to a piece of metal, your hand acts as a conductor of energy. Because the touch-sense circuitry is wired to detect changes in electricity, your hand can set off or communicate, if you will, changes in the electric property of the lamp with just one swipe of the wrist. The metal shell of the lamp cover is what detects the changes in electric current as caused by the addition of the energy in your body (transferred through the touch of your hand). As soon as the flow of electric current changes or is interrupted, a sensor is triggered and the lamp will then kick off or turn on.
    The basic function of a touch lamp is simple. Light is produced when the changes in electric charge are detected in the surface of the lamp. The flow of electricity is actually housed in the lamp's wiring, but the high frequency of the current travels throughout the surface of the lamp. Any changes in the electric properties of the lamp, as experienced with a single touch to the surface of the lamp, will cause it to alert the sensor housed within the lamp. Lamps of a more significant size will hold a greater charge and more easily recognize and detect touch.
    Because an electric current flows throughout the surface of the lamp, starting from the wiring and traveling to the bulb, a rate of capacitance is determined (e. g. the ability to collect energy). Smaller lamps will assuredly have a lower rate of capacitance than larger lamps and vice versa. When a person extends his hand to touch the lamp, the electric current found in his body will change the electric property of the lamp. In short, the change in electric current, as motivated by the touch of the user's hand will cause the lamp to turn on or off. Touch lamps can be turned on and off by touching the base, lamp cord or waving the hand near the lamp.
    In your case, (I'm guessing) that what was happening was when the fan motor speed is changed the electro magnetic force the fan motor generates is changed significantly. Now, the fan has an inductive motor and in the physics of electro magnetic force, inductance and capacitance have a relationship...you change one, you affect the other. Whats happening is that the temporary change in the inductance of the fan motors EMF also changes the capacitance of the fan motors EMF sufficiently enough to cause the same effect as touching or waving your hand on/over the lamp making them flash and sometimes stay on.
    The lamp bases act as antannae and they are designed to look for capacitive changes as written earlier.
    This tends to happen in circuits with inductor coils and motors. When the power changes or stops, the motor is still moving and the permanent magnets pass the coils inducing an electric current. Lightning causes the same effect, as the act of lightning involves massive current, inductive and capacitance events.
    I suspect that there is a pattern in your room, as distance is your friend.
    Does one lamp switch more frequently? The closer? Does the switching tend to happen more when going from fast to slow than the other way round?
    What can be done. As said, you must shield the lamps from the source.....again, distance is your friend. There are no guaranteed solutions but try moving the lamps (impractical) or using different globes. Often higher wattage are less susceptable. If the fan is an older model you might change it out...newer ones may have a different EMF signature.
    HOWEVER There is a risk that your problem is nothing to do with the afore-mentioned electro energy principals. You may be a victim of a bizarre mental connection that aliens have established with certain humans on this earth. Particularly those conducive to probing! They may be communicating to you via the fan and lamp EMF energies! Your only option if this is the case is to wear an alfoil hat similar to the type in the photo.
    Ralph
    its a back EMF fault out of the fan controller or the fan motor
    try the lights in different power sockets in the house and try some different bulbs in the lights.
    if that doesnt sort the problem you may be up to change the controllers on the fans or the fan motors themselves.
    The description of the way the lights work from ralph is entertaining and close
    the lights work much like an amplifier they detect the minute change in the electrical properties of the lamps casing when you touch it. For fun and games if you have little kids get them to find out what else they can touch the lamp with and make it change.
    Quote Originally Posted by Ralph1Malph View Post
    Ralph[/FONT]
    Dear Ralph, thank you for your detailed analysis of the problem and the solution. Unfortunately you left out the job safety analyses and risk assessment procedures. I made the hats, matching of course except SWMBO wanted one in pink (had to glue material to the foil). Sadly, while performing our biannual ritual SWMBO's antenna got caught in the fan and she subsequently flung around the room a few times, coming to rest in the walk-in-wardrobe. No real damage done although the ambulance officer gave me some funny looks when I explained about the hat.
    SWMBO would like to meet you face to face to express her gratitude, and just before she lost consciousness was mumbling something about knowing exactly where that ball of foil should go.
    Brisbane,some of the time.
    Sounds like you need an energy polariser,just make sure you put the crystals in the right place in the room.
    You will have to work this out yourself by trial & error,should only take a few minutes.
    Now everything will work fine
    Good luck
    Seriously,though,a relative of ours had a problem where turning on the fan in their bedroom with the remote control it was supplied with, also turned on an outside light.The outside light is powered all the time & has a light sensor built into it.He got the electrician back 5 times & the problem is still not resolved.....has removed the light bulb for the time being.
    Jan 2009
    Wheelers Hill, Vic
    try and get your hands on a couple of these, clip one or two around each power cable for the lamps, near the wall plug. look like magnets but they're called Ferrite Beads. You see them commonly on laptop power cables and what not.
    The fan controllers will be causing interference in the power circuit, so you need to shield the lamps somehow from this.
    Link on how they work. As it says, they're goal is to reduce electromanetic interference.
    http://computer.howstuffworks.com/question352.htm
    Found some on Fleabay!
    http://cgi.ebay.com.au/-FERRITE---BE...30202001r14874
    miky Guest
    I go with robzilla.
    Those damn lights come on real easy when they sense a bit of rf.
    Even the neighbours touch lamps.
    Jaycar sell the ferrite beads. Don't always work though.
    Bracken Ridge, Qld
    Mate if you are too lazy to use a damn switch, you deserve these problems !
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
