Thread: Drivers seat in my County is killing me
    Jas71 Guest
    Hi all, I have a 85 County and the drivers seat is killing me, im 6.2 and do a large amount of km. The problem is i have a second tank under the drivers and second battery under the pasengers seat so i need to get under them. Who make a after market seat that you can get under? Who can help me
    why do you need to get under the drivers seat with a second tank fitted there?
    relocate the filler or use a highflow pump to fill it from the main tank down the back....
    OR
    swap the battery and fuel tank left to right. How often do you REALLY check the battery?
    Wheelers Hill, Melbourne
    Seat extension rails may help. --According to this ads testimonial
    4wd accessories - recreational vehicle conversions - exploz pty.ltd. - australia
    mandurah
    Try Recaro or a Stratos suspension seat. Check the mounts out. I seem to recall the Stratos seat makes use of the existing mounts, and you can still access under the seat. I think Opposite Lock carry the Stratos range.
    Brisbane, Inner East.
    Not hard to lift them and move them further back. Need to lift at least 1" to clear the lip behind. Use some 1" square tubing and cut out some light plate to weld to it to make the bolt flanges. you need flanges on the bottom of the tube to line up with the holes in the seat boxes and flanges on the top to bolt the seats to. Four short lengths of tube and sixteen flanges. Piece of cake, particularly if you have access to a profile cutter or plasma cutter.
    URSUSMAJOR
