Results 1 to 10 of 17
Thread: Cylinder Head disintegrates on my P38 - 3 months after buying it.
    Sep 2009
    NSW
    Unhappy Cylinder Head disintegrates on my P38 - 3 months after buying it.
    Well, I now know what driving a P38 without any coolant causes.
    After the "little incident" mentioned in
    Using E10 Ethanol Unleaded in my P38
    when the top hose exploded from the engine, and my lovely P38 peed a waterfall of coolant all over the car park (my other half was driving, nothing to do with me I may add) I thought the engine sounded "a bit rougher".
    Over the past 1k km it's gone from a slight wheeze to a clicking... to now a distinct chuffing noise on the front nearside cylinder. Slowly, in low gear, you can feel the jerking as that cylinder is obviously dead. On the hottest day we had for 5 years - 43 degrees - last Friday I HAD to drive up the coast, and it got so bad when I was half way there I staggered into the nearest dealer. And they confirmed the bad news: gasket gone, cylinder head warped.
    That'll be a "basic" quote of $4000 please... probably a lot more once they see what other damage has been done.
    The dealer I bought it from refused to touch it, because I've just (by only a few days!) gone over the 3 month limit. Grrrrr...
    But I do have an aftermarket warranty - which will pay out a total of $550 for a dead cylinder head. Like that will go far!
    So... best / cheapest place to start taking the top off is I've found is the one p31aRover kindly mentioned in Sydney - half the price. Of course it's a $400 tow to get it there (car is still driveable, but I don't wana risk it...)
    This sounds cheap... is there a cheaper alternative... and do I dare take the risk of just doing the side that's gone phhht? In fact, I haven't done a Cylinder Head since my old Rover days in the UK.. can you just do one side in the P38?
    Oh, and three lessons learnt: if you hear a chuffing noise on each revolution of the engine... STOP! And as I've told the other half... if all the coolant drops out of the engine and it starts clattering like farm machinery... STOP! And for goodness sake, don't put that ethonol stuff in...
    Coogee, South of Fremantle, WA
    Sorry to hear of your issues. Have you given any thought to trying a Sodium Silicate type sealer additive even if its just to get you to the garage. I know many frown upon it but ................$$$$$$$$$$$$$.......??. I know what I would try.
    May 2008
    Bad news brother, I feel your pain.
    All is not lost, and you can do most of it yourself. All you need are a few good tools and patience... does this sound like a sales pitch? No, if I can do it anyone with some sense and willingness can do it... damn, still sounds like a sales pitch!
    I've documented a fair bit of the top-end refresh here Engine Refresh (top end) PaulP38A.com and will hopefully get around to finishing it one day.
    Most important thing is to get a new/reco set of heads. Hint: PM "Andrew e" on this forum as he might know a bloke who can help.
    You'll need new gaskets (heads, valley, manifolds, rocker covers), head and rocker cover bolts, and o-rings for the coolant lines. Might as well replace the hoses and serpentine belt at the same time.
    If you decide not to change over the tappets/lifters, make sure you replace them in exactly the same position. The general opinion on the forum is to change the tappets and camshaft at the same time. I elected to change only the tappets... so far so good. Changing the camshaft makes the job much bigger as you need to remove the engine.
    Suppliers I used for the job were http://karcraft.com.au, Gary Gjerde (clr4wdparts on eBay), and Canberra Motor Works.
    Cost in parts? I haven't worked it out exactly but think it was around the $1500 mark including reco heads. Most expensive part is the cylinder heads... perhaps your aftermarket warranty could at least cover that?
    Never mind the Nurofen and physiotherapy bills since then just be sure to practice good posture when leaning over the engine bay for extended periods of time.
    Feel free to PM me for more info if I can be of assistance.
    Cheers, Paul.
    Quote Originally Posted by lorkers
    Cylinder Head disintegrates on my P38A
    Well, that's a bit of an exaggeration. The head may need servicing but it should be OK.
    Quote Originally Posted by wayneg View Post
    It sounds like the side of the gasket has blown out. Sealer won't fix that. I had a 1" section blow out of mine and it also made a chuffing sound as I drove it home. See attached.
    Quote Originally Posted by PaulP38a View Post
    It can be replaced in situ. I did mine. You need to pull off the grille and, if I recall correctly, the oil cooler.
    Id pull the heads and measure them and the block deck first....
    Then make your decision on how to proceed.
    When the heads are off, get them hardness checked before spending any money on them. It's a simple test.
    Sep 2009
    NSW
    Happy Australia Day. Least it was, until the aforementioned "incident".
    Just for dramatic effect... well actually, the words of the stealer were "your head's had it mate...", but optimism rules eternal for the P38 driver, and I have hopes of it living again.
    Good pic... I haven't as yet seen mine...
    ...without pulling the rest of the gubbins? I'll try anything to see if it works before coughing for a new head...
    Re the cam, no, I meant after stripping everything else off, that's about all that has also to be removed. Oh, and water pump, timing case/chain/sprockets, and the slam panel (4 bolts).
    Aug 2008
    Darlington
    It seems to be an Australia Day Tradition, this time last year my P38 was being towed 400km from the south of WA! Good Luck with the rebuild!
    Quote Originally Posted by lorkers View Post
    Just for dramatic effect... well actually, the words of the stealer were "your head's had it mate...", ...
    Dunno how he'd know without pulling them off.
