Assuming its only just started getting hot and has been running fine up to now?
If its a V8 then I dont know... no experience there.
If its a tdi then you probably need to start looking at how to change the head gasket... Done several over the years, all start to go the same way and its usually between the back two pots.
The good news is if you catch it early there will be no long term problems - they are pretty tolerant in that regard. Just make sure you torque the head up properly.
Jon
