PM dullbird they have one in their Puma.
I like the location, but don't like the idea of the filler inside the vehicle.
Hi all,
I have read the threads on here about water tanks and I thank those people for their words and photos.
I am looking to purchase the 32L water tank from Opposite Lock - $365 RRP + installation. I am not interested in homemade systems as I do not have the skill nor time.
The following is taken from the Opposite Lock website...
"Fits inside LH Rear Wheel arch area Filler neck extends through floor to rear luggage area for security."
My questions are:
1. Do they have to drill the floorwhen running the hose up to the luggage area or do they use an existing drain hole?
2. How do they waterproof the floor with the hose running through for water crossings?
3. Exactly where is the filler neck installed in the luggage area?
4. Has anyone had trouble with the tap at the back as it looks vunerable to snapping off when off road on rocks etc.
5. Anyone know the cost for installation?
Your thoughts and experience is welcome...
You can download the installation instructions from Dolium
 Fossicker
						Fossicker
						great system. I have one on my Td5.
There are a couple of considerations however.
1. There is a large filler hole drilled into the top of the wheel box inside the rear. If you're water crossing above this level I suspect the defender would have already welcomed water inside in many other places. The large surface area of tank around this seems to seal the area and no dust ingress even.
2. The tank is subject to exhaust heat. Fine for cooking etc but can leave a plastic taste when drinking. Only really an issue in summer or up north. Fine for the rest of the year.
3. The tap location is ridiculous. I have moved mine higher on the crossmember using existing holes mostly to protect it.
Overall wouldn't be without it and a useful space saving inside the car.
Dane
Have a look at the other offerings from Dolium as well
Dolium Pty Ltd
I've got a 50 litre taper tank sitting up against the load barrier. (Tdi though)
Martyn
1998 Defender
2008 Madigan
2010 Cape York
2012 Beadell, Bombs and other Blasts
2014 Centreing the Simpson
VKS-737 mob 7669
I have one of the rear quarter tanks in my puma defender. It does let some dust in around the filler, but theres plenty from elsewhere so who cares.
I haven't noticed any plastic taste and we usually save it for drinking rather than drinking river water.
We have done a reasonable amount of high country 4wding since fitting and think you would have to do something silly to damage the tap.
The only hassle is refilling on a trip when you can't use a hose. I decant from a 20l jerry with hose and tap.
But as it uses dead space that it main plus. We travel 3 or 4 up with NO roofrack or trailer so the cargo area is at a premium.
PS match it with a quarter tank for fuel.
John D - Defender 110 2.4
 Fossicker
						Fossicker
						I had the water tank installed at the same time as the aux fuel tank. It has been extremely useful and I no longer have to worry about a loose water container rolling about in back. Something simple like washing your hands is now ridiculously easy. The internal filler isn't flush and does occupy a small potential storage space because it sticks up, but I haven't noticed any loss of space because it is on the shelf and near the door anyhow. My filler was sealed with sikaflex at installation and is airtight and has withstood a fair bit of abuse by being accidentally bashed with SCUBA tanks, lead weight belts and other heavy loose load ojects.
My tap was originally installed at the small hole to the right of the step.
This (1) caused the hose to be kinked when the step was operated and (2) also became a natural second step for anyone climbing into the back...not good for the longevity of the tap!!
OL cheerfully relocated it to the present location on the other side of the towball when I pointed out the hose kinking issue. The current position seems pretty bulletproof and although I haven't tested it at maximum depature angle the tap can swivel sideways before bending/breaking off.
The only issue I have found is that in the installation process the mudguard is relocated rearwards and the mount isn't as secure as the original system. My mudguard came off in heavy mud after the installation and I will have to keep an eye on it in the future.
I drink all of my water out of plastic...whether it is from the rainwater tanks, plastic bottles or the car tank so the "plastic taste" isn't an issue.
Mark
 Member
						Supporter
						Member
						SupporterHi,
over many years in the bush with a variety of external water tanks I came to the conclusion that an internal tank was best consequently my last two Defenders have had a 57 litre plastic tank from Engel that fits snugly along the LHS between the rear seat and rear window. Filler is near door and outlet is down low and with a length of flexible hose with a small tap INSIDE the vehicle means that that the tap is never dirty of clogged with mud or whatever comes off the road. 57 litres of water more than compensates for the weight of the 35 litres of fuel in my auxiliary on the other side. Best part is that it can be moved to another vehicle or out when you need the extra space.
Good luck with your deliberations.
Rock Doctor
