I've just wired up my caravan for towing with the D3, so maybe I can help.
Firstly, if you don't need to send power to the trailer (via main or aux battery), then just use the black socket (on the right, looking at the back of the vehicle). Most car accessories shops will sell you an adapter to fit your trailer plug - Repco definitely do!
If you need to run power to the trailer, things get a little more complicated. Essentially you need to use both sockets on the D3 and make a "Y" loom to attach to your trailer's plug. But to help here, I'd need to know what type of plug you have on the trailer, and how it's wired - eg there are varying standards across Australia for the 12pin plugs that are used on the larger caravans now being made.
Gordon
….. also the socket is different to most that I have seen on Australian trailers….. is there an adapter I need to get my hands on?
