Disco Transfer in a defender
Hi Guys,
I have a 2005 td5 Def and want to put in a Disco LT230 but don't know much about them. I want better gearing for the hwy and less noise. I have found a second hand LT230 which is apparently a Q model serial number A936D719054G cross drilled type.
A couple of questions for those in the know:
1, Can I swap the gears from this into my defender box?
2, Would this have the centre diff lock and will I have to swap my top cover plate? How do I tell if the CDL is there?
3, Will the handbrake and speedo all be in the same spot, easy swap over etc
Thanks Guys!
Current - Silver 2007 SE D3
2005 Defender 110 Wagon TD5 - Gone :(
