Results 1 to 10 of 13
Thread: D3/4 driveline strength
    99.87 MB
    Hi folks,
    Has anybody heard much about driveline failures in the D3/4/RRS? I had never heard anything about it until recently where a D4 broke a CV. Just wondering if this was freak or if the incidence of failure will increase with harder use and age.
    Slunnie
    Nedlands, WA
    Not really Slunnie!
    I have heard of some snapped CV joints in D3's, but these were when in extended mode at full lock. I daresay there would be increased risk with those vehicles that run shortened height sensor rods. But i's definitely not a common thing.
    There is (I believe) a mob in the UK who are (have?) developing a tougher CV joint.
    NSW SW Slopes
    Quote Originally Posted by Jamo View Post
    ..in extended mode at full lock.
    I cringe at the thought of applying much power at all on full lock with such a tight turning circle.
    Nov 2008
    no "brakes" as such,,, just clunking cv's, wineing diffs stuff like that
    Ballina, NSW
    This used to be a big problem in the early days of "Hot Hatchs". Turbo charged 4cylinder motors developing 200+kW…… didn’t cost much money……. And as a result 200kW in the hands of 18 year old plonker……. Pulls up at a traffic light turning left……. Wheels to full lock and dump the clutch……. Snapped CV…….
    The amount of power, and for more importantly in this discussion, torque that is going through those front CVs on a D3/4, at full lock, with the added strain of extended mode, and the inertia of a 3 ton vehicle, scares the hell out of me……. I tend to be careful with the power application (and I only have a V6) and try to avoid planting the right foot in anything but a straight line…. I am probably over cautious, but the point I am trying to make in a roundabout way, is that one needs to understand one’s vehicle, the mechanical limitations (not necessarily unique to a specific vehicle), and drive accordingly……
    Just my 2 cents…….
    No engineering solution can make up for common sense
    Ballina, NSW
    Quote Originally Posted by Tombie2 View Post
    X2!!
    I am sure you get them here too, but there is a special kind of 4x4er we get in South Africa...... you will all be standing around an insurmountable obstacle, pondering options…… a tricked out cruiser will pull up, a large gentleman steps out and says to the closest person “heer, hou my dop, nou wys ek jou ‘n ding” which loosely translated means, “here, hold my drink (brandy and coke more often than not), let me show you something”……. Said person sets off…. Net result is a broken cruiser, a smashed ego, and a few grinning Land Rover drivers……. Oh, and the obstacle is still insurmountable………
    Warrandyte, vic
    I wonder if transmissions will become a more common failure as these vehicles get older.
    Transmissions are being replaced on vehicles used for towing.
    Towing will result in higher atf temps which may be replicated with extended off road use.
    As these vehicles become cheaper they will be used more off road, the maintenance will drop, that $100 a litre atf fluid wont get replaced and transmissions will go bang.
    G'day Slunnie
    Not a breakage as such but Herve's D3 once snagged a CV boot at Jenolan. If that wasn't picked up it would no doubt lead to premature failure.
    Max P
    Melbourne, mostly
    Interestingly, the D3, the car that can tell you if so much as a brake light sensor malfunctions for a nanonsecond, has no way to let the driver know a CV joint is snapped. You may think the driver would notice, and of course you know something's wrong, but not what.
    A tip, if you need to drive out with a broken CV use Rock Crawl as that prelocks the centre diff which is what you'll need to do to avoid all the drive going to the broken CV. Other modes work but RC is best. It's perhaps the only time I've wished I could lock a D3's centre diff manually.
