Results 1 to 10 of 16
Thread: Old PC disposal
    Nov 2007
    On the road.
    Old PC disposal
    hi folks,
    twofold problem here.
    1. old pc has crashed (press power button makes noises but nothing happens) and want to clear files off it before disposing.
    2. where is the best place to get rid of old pc's.
    should i just pull the hd out of the tower to make it safe?.
    appreciate the advice.
    thanks
    May 2002
    Heathcote (in "The Shire")
    I would pull the HDD out and either, install it in another PC to get whatever you need off it, or buy an external HDD case and use it that way.
    Whatever you do when you have finished with it destroy the drive before disposal (I normally belt a punch through them a few times)
    Martyn
    Adelaide SA
    Pull the hdd out, & delete the files with another pc.
    You can also use a program such as Disc Shredder to ensure all data is erased and is unrecoverable.
    To get rid of the actual box, ring your local Rotary group & see if they take them.
    Some do, and either re-build them or recycle them for use with those that cant afford to buy one. Failing that, put it out on the nature strip with a "give-away" sign. It should go fairly quickly.
    Stops the whole thing going into landfill.
    St Helena,Melbourne
    4.28 MB
    Nature strip - then i can come along and raid it for parts
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Western Victoria
    1. If you have files you want to keep, for a few dollars you can get a lead to connect the hard drive via a USB. Then, either crush it or format and fdisk it. If the info on the HDD is sensitive, then buy a software shredder as previously mentioned. I may have a trial version somewhere or you may be able to download one from the net.
    2. There are several charitable organisations that recycle old PC's. One here in Vic is PC's for kids. The local Rotaty group send them to a warehouse in Melbourne to be refurbished and sent overseas to small schools in Asia and the Pacific Islands.
    There's bound to be organisations such as these in NSW. Look in the phone book.
    And if anyone has any IDE hdd's 80gig plus i will buy them.
    Really!!
    You'd travel that far for an old PC?
    May 2002
    I was assuming you wanted to 'dump' it once you had finished with it. If you want to pass it to someone else run 'Boot n nuke' over it first (note that it will wipe ALL HDDs on the computer that it finds)
    Martyn
    Nov 2007
    On the road.
    Quote Originally Posted by Mick_Marsh View Post
    Really!!
    thanks, might look into this. only photos which i have backups but still no reason for others to see if i pass the machine on.
    thanks
    Yass NSW
    For the record no disk cleaning product is certified to permanently wipe the disk.
    Thats why we melt down the HDD's.
    Bracken Ridge, Qld
    Quote Originally Posted by George130 View Post
    Yeah cool eh !
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Sorry, rubbish. The Apple one offers options that exceed the US department of defence standards. I'd be surprised if all the other UNIX/LINUX distributions wouldn't offer the same kind of thing.
     2005 Defender 110 
