Results 1 to 10 of 21
Thread: Front chassis cross member assistance please
    drifter Guest
    Hi,
    A couple of months ago I 'rescued' a 1971 88" 2a from a paddock near the South Coast (NSW). The vehicle was complete but has a very rusty chassis and there is quite a lot of rust in the firewall. Mechanically, it all seems intact and recoverable (It would need things like a replacement exhaust manifold).
    Today I went to look at (and purchased) an older 2a that has been sitting in a paddock not far from here for a couple of years.
    The chassis and firewall are in excellent condition - except for 2 things:
    1. it is a 109"
    2. the front crossmember has been cut out, flipped over and re-welded in as the PO was going to put a holden engine in it.
    Apart from the missing engine - it is all complete and looks good (pictures to come when we do the recovery in the coming 7 days).
    Now, my dilemma. Do I continue to look for a donor 88" chassis or do I shift focus a little and try to resurrect the 109"?
    If it is easy to re-cut the front crossmember out and put it back where it belongs, it that feasable? I could probably use the crossmember from the shagged chassis as that is still OK. I could then think about moving the engine from the 88" across to the 109"
    You guys have done all of this stuff before, I haven't, so I would appreciate your input.
    Thanks in advance
    drifter Guest
    I should also mention that, whatever I do, I am going to have to do quickly as she-who-shakes-her-head-a-lot is not going to be too impressed with 2 Series 2 vehicles getting stripped on her front lawn.
    depends on what you need and want it to do.
    the SWB was great for me when I was only doing recovery work or mechanicing work but once I started putting both hats on at once or needed to carry more than one other person the SWB was just too short.
    drifter Guest
    Thanks, Dave
    What do I want it to do?
    I have been sitting here pondering the same question.
    I used to have a 1957 LWB Series 1 and found it to be a very handy 'utility' for carting stuff around.
    I chose the SWB 2a because it was free and because I was assured it was in great condition - so I went and got it. It is only the after sale inspection that showed up all the problems with rust (I am a novice - making mistakes and bound to make a few more).
    The desire is to have something I can drive - sometimes take it to work (the Disco is racking up way too many miles, expensively) - something I can continue to carry 'stuff' in without having to strap it to the roof...
    I am thinking that I'll try to get the 109 roadworthy
    so - how feasible/problematic is it to replace the front chassis crossmember. Legalities? Problems with registration?
    its easy...
    how good are you with the welder and the cutting gear?
    drifter Guest
    absolutely hopeless
    but I have a friend.....
    if you say it is easy, I will look more to that path than any other.
    JDNSW's Avatar
    Quote Originally Posted by drifter View Post
    Thanks, Dave
    Should be easy as Dave says for a competent welder. Legally the vehicle has the identity of the chassis (number on LH rear spring hanger on the flat above the shackle - you'll probably have to remove all the paint to see it). All you need to do is to have a receipt for that vehicle and the one with the engine.
    Just check that the 109 is not a six - it gets more complicated if it is. Easy to tell - the six has the engine/gearbox/transfer case further back, just check the two firewalls have the same size bulge for the engine - the difference is very obvious if you compare them.
    drifter Guest
    Thanks John.
    The receipts will be a worry. The first one was given to me - I didn't ask for a receipt for the second...
    I'll chase that up.
    As for the 109 possibly being a 6 - he told me they (the owner before him) had taken a 2.25 out of it before he got it.
    dont panic about that they'll take a stat dec.
    drifter Guest
    It will be a while before I am at the rego stage so I'll have something sorted by then.
    Thanks.
