Results 1 to 10 of 14
Thread: Clutch Question
    woofy-5 Guest
    Clutch Question
    Hi all i will be changing my landy six to a holden if i can ever find the parts i need what i would like to know is will the landrover clutch pressure plate bolt strait onto the holden fly wheel or will it have to be redrilled its a 1974 109 and i want put a 186 in .
    thanks up front Shane
    no, from memory the bolt pattern is different, but then Ive never done the conversion from rover to holden, usually its the other way around.
    Nov 2006
    Wollongong NSW
    You will have to re drill the flywheel to take the L/R clutch /PP.
    Also a special spigot bush is needed. Thats what was done in the later conversions............
    Nov 2006
    Wollongong NSW
    Thinking back i think the kit i still have is a Rover flywheel drilled to fit a holden engine. I think they machined the flywheel to fit the holden ring gear.
    It's buried in the archives somewhere i would have to dig it out to have a look.......
    woofy-5 Guest
    clutch question
    Thanks for the help groucho and blknight can i buy a spigot bearing or would i have have one made thanks Shane
    you can buy one, its not a holden or a rover item from memory and its easier to purchase a lump of sintered brass and have one machined up. its not a super precise bearing so its something your average handy man can DIY on a hobby lathe.
    Nov 2006
    cardiff ,NEWCASTLE.
    TRY marks adapters in melbourn OR DELLOW automotive in sydney i know dellows still do the kit not sure about marks though.
    i have the 202 blue & mine is a holden flywheel machined to take the rover clutch...
    i rang marks years ago & they sent me up all this info was about 30 pages all on fitting holden engines in landy's..I'll see if i can find it i know i wouldnt of thrown it out..its a good read..
    1969 LWB S2a yellow, gone
    1972 LWB S2a 5 DOOR wagon coming & GONE
    1973 LWB S3 green Sadly GONE
    1977 LWB S3 tabletop building
    1992 disco BOINGY BOINGY
    My landrover doesn't leak oil , IT SWEATS POWER
    JASON & KAREN
    woofy-5 Guest
    Clutch Question
    Thanks Banjo that would be great Shane
    Nov 2006
    cardiff ,NEWCASTLE.
    Hey shane i found all the info i told you about i will try scaning it & post it up for you sometime today..i also have the dellow catalogue as well but its in book form dont know how to scan that.i have to use the old computer to scan so it mite take me a while...
    JASON & KAREN
    Nov 2006
    cardiff ,NEWCASTLE.
    Ok lets see if i can get this right they mite not be in the right order..here goes
    I hope these are of some help....if you ring them they could probably send the same to you for the rover six to holden 6..mine was origanly a rover 6..
    JASON & KAREN
