Results 1 to 10 of 12
Thread: bodgy tyre repair job
    During a race I went in last weekend I tore open my rear tyre and grazed the tube subsequently developing a slow leak on the tyre. Not wanting to make matters worse and have to ride on a brand new rim or carry the bike for the remainder of the race I decided to quickly patch it up, it's kinda hard to patch up a tyre quickly so I asked myself the question, what would the king of Bodge jobs do in this situation? We had no electrical tape so chewing gum and a crepe bandage had to suffice. It worked and surprisingly lasted with air in the tube till the next morning.
    You may laugh, but it worked and we only lost two minutes
    Also a question
    Had to get a new tyre today, decided to go a bit bigger up from 1.95 up to 2.20. There is only 5mm clearance between the tyre and frame and again on the tyre and V brake. I cannot see an issue. I have the original 1.95 on the front (they only had one 2.20 left on special) so the front sits a tad lower. Any problems having it like this short term?
    WA
    Quote Originally Posted by dobbo View Post
    Love your work!!!
    I am not sure why you want bigger on an XC race bike? Most people want to go smaller to save weight. (that said, I run 2.5s on my FR bike...)
    It would be preferable to put the fatter tyre on the front and the skinny on the rear. The theory is the same as with cars - you need traction at the front more than traction at the back.
    Or - to put it another way: Oversteer is when the passengers are scared, Understeer is when the driver is scared.
    richard4u2 Guest
    back in the days in the post office as a postie we had thorn proof tyers you pump em up rock hard and nothing stoped them, you might have to put a bit more effort into it when in a race but you didnt have to stop for any reason, but those were the days when men were men
    so long as the rubber aint rubbing you can run what you like. and theres no problem running a skinnier tyre front or rear.
    on the soft stuff I used to prefer the fatter more agressive rubber at the back and I used to throw the weight back and "float" the front wheel over the soft patches
    on the slippery surfaces that could hold weight Id have the fat agressive stuff at the front.
    Good drills on the bodge.
    serpintine wa
    nice one have you thought about dobble tyreing the rear???
    Yinnar South, Vic
    Where does the engine go?
    Crafers West South Australia
    Quote Originally Posted by rovercare View Post
    Here:
    au
    Just go tubeless with sealant and you will not have to worry too much about a flat tyre again.
    WA
    Quote Originally Posted by jaseh View Post
    Yeah - maybe time for the cheap tubeless system. You need two BMX tubes and some sealant. Cut the BMX tube around the outer perimeter and stretch it over the rim. Trim off the excess once you have the tyre on.
    May 2006
    Quote Originally Posted by richard4u2 View Post
    I also had 28 inch thornproof tyres on a bike many years ago. More recently have had a 26 inch bike with "thornproof " tubes with rubber about as thick as in car or tractor tubes with green "Slime" sealant in them .
    However would still sometimes have flat problems with bindiis around here. Several months ago mentioned to local bike shop owner that would like to get thornproof tyres if they were available. He had some. Made in Indonesia, apparently in same mould as ordinary tyres as external appearance is identical. However, they are a lot thicker under the tread.
    I think the story is that an importer in Geelong has had them made. Probably lots of bike shops would now at least have an idea where to get them. Retail price here for 26 inch one currently $30. Still running thornproof tubes with slime in them. Total cost to instal these items on bike about $100. Not cheap but worthwhile in areas where normal tyres and tubes would have lots of punctures.
