Results 1 to 4 of 4
Thread: td5s bottems
    Nov 2008
    td5s bottems
    has enybody herd of the bottem end on a td5 fail?? iv seen a td5 with 370k on the clock and its still going strong
    Yinnar South, Vic
    Quote Originally Posted by stig0000 View Post
    Nope, everything around it, just not a bottom end, complete failure
    Depends on how you define letting go. If you count spagged bearings then yes I have but it was a symptom not a cause. The oil pressure relief valve spring was soggy and was maintaining just over minimum oil pressure the engine was chipped and the guy driving it wasnt renowned for having a light right boot.
    If you mean "well there I was just happily fanging a long and all of a sudden I saw what looked like a con rod and piston jump out of the bonnet" then no.
    Kingston, Tassie, OZ.
    Hey Stig,
    Not very often, usually due to something like that little oil pump bolt coming out....
    I reckon they are a pretty strong jigger actually
    JC
