Thread: lpg tank capacity.
    Dec 2008
    blackbutt qld
    lpg tank capacity.
    Have been looking at the posts re LPG tank capacities and I may be wrong but surely a 60l tank is a 60l tank. That is the volume of the tank. No matter what you put in it, LPG, water or treacle, its still a 60l tank. The weight or mass of what you put in there will be different, but it will still be the same volume.
    Apr 2007
    Prospect SA
    All modern lpg tanks have a fill limiter valve that limits filling to 80% of
    their water capacity. This is to allow for expansion.
    I have had a couple of conversions now and asked the installer similar question.
    brisbane , QLD
    haha i just went through this. i finally seen the stamp inside the cover and it says 110 water capaicty but i can only fill it with 75ltrs of gas from empty. so theres plenty of room for expansion it seems
    Quote Originally Posted by disco97 View Post
    Your fill valve may need adjustment of the float -- or the tank my not be installed correctly. You should get about 88 litres in.
    Crafers West South Australia
    Post a picture of your tank and the inside of the control box, we'll soon tell you what's wrong with it.
    Water capacity means exactly that, it's a recognised test for stretching, and can be done on a simple weighing scale. Less error than with ladling litres of fluid in.
    LPG capacity is set by the automatic fill limiter (AFL) and by law (AS1425) should shut off at +/- 2% of the rated LPG capacity. In the example of the 110WC tank it should fill to 88 +/- 1.75 litres. Otherwise it's not legal!
