Results 1 to 10 of 11
Thread: Removing side decals from a defender
    fin56 Guest
    Hi all,
    The paintwork on my 95 defender wagon is looking a bit shabby, so I thought I would give it a nice cut and polish. To do that job properly, I need to remove the side decals. (which are also looking very faded and sad, so I will either put new ones on or just leave it with no decals) Does anyone know a good way to remove the decals without damaging the paintwork? Is there a particular solvent I should use to soften the adhesive that won't attack the paint? Or is there another way to remove them? The old decals seem to be very well stuck on and quite brittle also. Any ideas would be gratefully received!
    Craig
    Apr 2002
    Bellara 4507
    32.43 MB
    seen it done with a hair dryer and then eucalyptus oil to clean up.
    no doubt there are other ways as well.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Nov 2007
    Gold coast
    Yep hair dryer will do the trick, as will accetone to get the glue off, then a good compond polish will help to buff up the lines..
    fin56 Guest
    Quote Originally Posted by juddy View Post
    Thanks to juddy and incisor. I will dig out the hair dryer this weekend and give it a go.
    Craig
    May 2006
    Redesdale, Victoria
    Fin
    Did the same to mine but not cut it back yet. I didn't use the hairdryer but believe it is an effective way. I peeled them off VERY carefully and used elbow grease to get the glue off. Patience is your friend.
    Where abouts are you in Melb?
    Chris
    I've spoken to a decal / sticker sign writer who had a whole fleet of cars with old decals to remove. He had good success using an electric kettle to steam them off.
    Just watch you don't get steam burns.
    diso Guest
    Gday, try a caramel wheel (pin stripe removing wheel) from an auto paint supply.
    Oct 2007
    I've used a heat gun to get them off (with care) & was pretty efficient & reasonably quick. I cleaned up with petrol...thought it might be a bit kinder on paint than acetone or thinners.
    Bracken Ridge, Qld
    I tried the eucalyptus thing.. don;t bother.
    I got the decals off my 130 as follows:
    1. Roll vehicle.
    2. Repairer has to put new panels down one side.
    3. Repairer says he can't get decal to match other side, so do I want both removed, or replaced with newer ones.
    4, I opted to have them remove the other one as well.
    Job done. Easy.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Scarborough, QLD
    Quote Originally Posted by VladTepes View Post
    1. Roll vehicle.
    Job done. Easy.
    I notice some cheaper ones for sale on ebay at the moment, if you're looking to put them back on
