Results 1 to 4 of 4
Thread: D4 Caravan and Rear Mounted Battery Kit
    Queensland
    D4 Caravan and Rear Mounted Battery Kit is now available.
    The kit $360 including Express post Australia wide and this kit will also fit a D3.
    The kit comes with everything required to install a dual battery system except the battery and battery box ( see below ).
    The installation also includes a rear mounted Anderson plug for charging house batteries, when towing a camper trailer or caravan.
    The installation takes about 3 hours and there are no holes to drill, no cables to cut and more importantly, no terminals to crimp.
    All the cabling comes cut to the correct lengths and all the heavy duty battery cable size terminal have been crimped in place.
    There is comprehensive installation instructions, including loads of pictures, are provided on a CD.
    The instructions show where to run the cable, which panels need to be removed and how to remove and reinstall each panel.
    The finished installation has everything out of the way and out of site, particularly in the rear when the battery box is not being carried.
    At this point I’m working on a battery box with a number of features and different types of plugs and connections and this should be available soon.
    I’ve not put the full details up on my web site yet and there are a number of other kits to be available in the next week or two.
    For more info you can phone me on 07 5569 2557.
    Subiaco, Perth
    Please advise what we get for our $360.00
    Queensland
    Hi DISCO 4, the contents of the kit is listed below and you get the cabling supplied with all terminals fitted.
    SC80-LR Dual Battery Control Module with pre-wired Circuit Breaker Box + Red & Black Anderson PowerPoles.
    Red Battery Cable in black Split Tube with 8mm eye terminal, & Black Anderson PowerPole.
    1 x 8mm Stainless Steel Bolt and Stainless Steel Washer.
    6m x 6B&S Twin Sheathed cable with 1 x 120 amp Anderson Plug ( fitted )
    1 x 75 amp Anderson RED PowerPole
    1 x 50 amp Anderson Plug
    1 x Dust Cover for 50 amp Anderson Plug
    1 x Cable Boot for 50 amp Anderson Plug
    1 x Large Black Heatshrink
    1 x 1m x 6B&S Twin Sheathed Rear Battery Connection Cable
    2 x 8mm Eye Terminals
    2 x Small Heatshrink ( 1 x Black, 1 x Red )
    4 x Alcohol Swabs
    4 x Wire Ties.
    1 x Installation CD
    Queensland
    Here are some pics of the finished install.
    This is the kit. NOTE, the second 120 amp Anderson plug will be pre-assembled on the end of a 1m cable for connecting to a battery box.
    This is the pre-assembled main cable.
    This is the location of the control module in the Auxiliary Battery Box, on the driver’s side of the engine bay.
    This is the 120 amp Anderson plug laying in the cargo area.
    This is the 120 amp Anderson plug stowed away in the Jack Compartment
    This is the finished and stowed 50 amp Anderson plug at the rear of the D4.
