Results 1 to 10 of 13
Thread: Anyone good with irrigation pipe/pump calcs?
    May 2006
    Woolgoolga
    Well another saga in the homebuilding, but here we go.
    What i have is approx 300m of sub surface irrigation for our waste water treatment plant. 50 of those meters are 25mm poly, the other 250 is 17mm pressure compensated pipe with 1.6l/h drippers (press/comp) at 600mm apart.
    Now this is split roughly in half (2 runs,1 at 170m(35m poly) and the other 130m(15m poly))
    For all these drippers to open at once the pipe must have 110kpa at the ends. The pump i have flows a 9m (230l/m?)head but will only open about a third of the drippers (most of the down hill ones).
    So who on here is smart enough to do the calcs and tell me what size pump will do it correctly
    Am going to run my shed pump opn it tomorrow, which flows 28m head (flow rate?)
    The other pump i can buy for this system is 11m head and 320l/m.
    Anyone?
    Crafers West South Australia
    First off 9metre head is only 88kPa, flow rate you need is no. of drippers x 1.6l/hr divided by 60. Add 25% pressure loss (guess only) you should have head pressure of 137kPa /14metre minimum at your calculated flow rate. This aint no transfer pump rating, a higher pressure house pump might work.
    busy forum again
    as described above and out of my hydraulics books....
    110Kpa is more or less a 11m head height + 25% for 14m head (roughly) (this 25% is to account for pumping ineffeciencies, minor deviations in head heights, minor flow restrictions after the pump)
    your flow rate is # drippers X flow rate @ pressure per hour.
    so assuming that the calculated flow rate of 1.6l/hr is based on the 110kpa working pressure stated.
    500m of drippers at .6m spacing is 500/.6= 833.3---- drippers call it 840.
    the drippers drip 1.6l/hr so thats 840*1.6 thats 1344l/hr
    flow per minutes is that /60 1344/60 = 22.4 call it 23l/m
    you need a pump that can push 22.4l/min into an operating head of 14m.
    sans out the 25% fudge factor and round the numbers down.... and
    830*1.6/60=22.13---- call it 22l/m into an 11m head.
    richard4u2 Guest
    you hit the nail on the head when you said the down hill ones to get pressure out of your system always push water up hill , can you run a pipe from your pump to the bottom of your system ?
    Mar 2009
    Port Stephens N.S.W
    Quote Originally Posted by richard4u2 View Post
    Won't matter. Drip line being used is pressure compensated. Pressure consumed to raise the water to the highest point in the line is gained back on the downhill run ... less pipe friction losses.
    Kev..
    Mar 2009
    Port Stephens N.S.W
    For mechanicing call Dave, for hydraulic engineering call me.
    How about you check your numbers Dave
    300m x dripline @ 0.6m spacings = 500 drip emitters
    500 emitters X 1.6l/hr = 800l/hr
    800l/hr / 60(min) = 13.33l/min. TOTAL FLOW
    Head loss is calculated for the longest run of pipe only. The shorter runs need less pressure.
    Longest run = (35m x 25poly supply line) + (170m x 17mm dripline - 284 drip emitters @ 1.6l/hr = 455l/hr = 7.6l/min
    The loss in 35m of 25 poly at a flow rate of 7.6l/min (0.126l/sec) is SFA. (My head loss curves are at work, but it is neglible).
    25 poly is good for 45l/min (0.75l/sec). More than that and the velocity exceeds 1.5m/sec and the head losses become a J curve.
    19mm poly (i realize 17mm is being used) is good for 20l/min or 0.333l/sec ... our flow into the 17mm poly is only 7.6l/min, and every 0.6m we take out 0.0256l/min, and the flow (& velocity & loss) in the next 0.6m drops ... and every 0.6m ... the loss in the drip line for this installation is negligible.
    ... so without splitting hairs add 1m head required.
    110kpa = 16psi + 1.4psi head loss (1m) and we want 17.4psi ... don't dick around, call it 20psi.
    So our head required is 20psi - 14.1m - 138kpa
    Our total flow is 13.33l/min.
    You need a pump that can deliver AT or BETTER than 13.33l/min at 20psi ...
    This all assumes a flat ground delivery ... if you need to raise the water thru 4m to clear the highest point in the system, ADD 4m to my workings ... deduct if your going down hill lower than the pump.
    1psi = 2.31ft
    1m = 3.28ft
    1psi=6.895kpa
    You can do the math.
    ... PLUS your suction losses on the pump need to be added to the above calc's ... it will have a loss at flow that needs to be overcome (but I'm guessing your using a submersible pump by the flow rates/heads you're quoting ... right ? They don't develop the head required for your application. small/medium subs 150-400l/min are usually shut head (no flow) of around 8 to 12m (17psi and NO FLOW) ... they are designed to move big volumes of water quickly over small heads ... for dewatering.)
    So if it is a sub .... and your pipe runs quoted are correct ... this is the calculated INPUT your system needs to work ....
    15l/min @ 20psi - 15l/min @ 11m - 15l/min @ 138kpa .... or BETTER. Always choose a slightly bigger than required pump.
    Nuff now.
    Kev..
    ... sorry, just to add. The reason you existing pump won't do the job is it cannot overcome the inherent losses in the system it's connected to. Those flow/pressure figures you quote are probably maximums ... ie:max' flow & max' pressure ... you can have one or the other but NEVER both at the same time ....
    Nobody makes pumps for this type of application, and subs are cheap, so that's what gets used, but I bet your 9m pump has ZERO flow AT 9m head ... got a pump curve for it ?
    ahhh so thats what happens when you transpose a number.....
    least I got the head pressure right.
    Bathurst NSW
    but if he decides to run 500m of pipe he can use your numbers
    <a href=https://the4wdzone.com.au/wp-content/uploads/logo.png target=_blank>https://the4wdzone.com.au/wp-content/uploads/logo.png</a>
    The 4wd Zone/Opposite Lock Bathurst
    263 Stewart Street, Bathurst, NSW
    http://www.the4wdzone.com.au/
    Discounts for AULRO members, just shoot me a PM before you purchase.
    May 2006
    Woolgoolga
    Quote Originally Posted by Fluids View Post
    1psi = 2.31ft
    1m = 3.28ft
    1psi=6.895kpa
    Nuff now.
    Kev..
    love ya work, any way from all this i can tell you that it is not on level land, some would flow up to 3m head and some down 3-4m, and some on level ground. I hooked up my shed pump today (28m/head) and all drippers opened and worked, however this was hooked to my water tank, the 9m pump is built into the treatment plant. So by subs you mean a second tank and pump to pump the waste through the irrigation?, So the pump that deliver 320l/m at 11 m head wouldn't cut it either?
