Results 1 to 10 of 26
Thread: What are some easy mods??
    Feb 2010
    Townsville
    Hi i just got my first defender tdi 300 an want to know some cheap mods staight up i can do.
    serpintine wa
    remove the main muffler you wont regret it
    other wise scrounge and use your brain to build things like sliders draws ect
    Allestree , its all good.
    Rotate the hand break lever away from your leg , or get rid of it all together and put a rangi / disco one in next to the cubby box.
    Set of 20 mil tube seat rails ( new longer high tensile bolts req).
    Think of something or do a search here, some ones bound to have done it before.
    '99 Tdi 300 130 Twin Cab
    When I'm here I want to be out there.
    Nov 2006
    cardiff ,NEWCASTLE.
    You could sell it & buy a real lany with leaf springs not BIONGY BIONGY ones but thats just me..
    1969 LWB S2a yellow, gone
    1972 LWB S2a 5 DOOR wagon coming & GONE
    1973 LWB S3 green Sadly GONE
    1977 LWB S3 tabletop building
    1992 disco BOINGY BOINGY
    My landrover doesn't leak oil , IT SWEATS POWER
    JASON & KAREN
    Quote Originally Posted by banjo View Post
    That will be quite enough of that....
    that attitude is reserved soley for use against puma owners.
    back on topic
    what did you want to achieve? are you modding for the sake of modding or do you have an end objective?
    Feb 2010
    Supine
    Some cheap mods...let's see...Scouse, Pedro the Swift...
    Western Victoria
    Muzza99,
    Silly question time.
    Why do you want to modify it? What doesn't it have that would improve it? (apart from communications equipment of course.)
    I like my boingy boingy Landy.
    ps Thanks Banjo, that got a giggle
    Jan 2009
    Far North Qld
    a cheap mod
    If your shock absorbers are standard,,lower the top of the rear ones, by 2 inchs,(50 mm).
    Nanny state UK...
    I'm another one which would question your motive.
    If you're changing things just for the sake of it, don't bother (if it ain't broke, don't fix!). Instead, just spend your time & money getting it serviced properly.
    Also, if you're new to this 4x4 thing, get some training. Decent servicing & proper driving skills will save you loads of grief (and $$$) as you will be less likely to break things. (Getting stuck, with a broken car is a PITA!)
    My 2c
    M
    Jan 2008
    Nowra NSW
    1. Dual batteries in the standard battery compartment.
    2. Mod rear seats so they swing forward for easy access to under seat
    storage area and on mine I made them quick removable. (130 )
    3. shave rear diff ......quick and easy job to gain 1/2 inch clearence
    4. Add heavy duty axle drive flanges and replace worn axles if required.
    5 Add head light relay so head light switch doesnt burn out.
    6 add brass plumbers BSP plugs to radiator and thermostat housings and the same size fits the gearbox oil level plug so you will not need a special tool to undo it and can use a shifter.
    7. Add dual power sockets to the rear tray or HCPU ( 130 )
    8. Add grease nipple to drag link rod ends.
    9 Use Z9 filter for lube on motor.....cheaper and no problems,
    10. add extra fuel filter by replacing the water trap at the LHS rear wheel with a CAV type filter with a glass bowl as it is cheaper to replace that filter and you can see whats going on with the glass bowl.
    All cheap and easy stuff to do.
